odd leak - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-18-2009, 12:23 PM Thread Starter
87pony's Avatar
odd leak
I have a leak that shows up after a little bit of driving. Its leaking oil and looks like spraying or running down my down pipe. Is it possible that the transmission is leaking oil between the housings (t5) and spraying? have not gotten a real good look at it yet.
87 gt- hci 70mm snail
87pony is offline
post #2 of 4 Old 08-18-2009, 01:53 PM
More than likely it's the rear main.
87TurboGT is offline
post #3 of 4 Old 08-18-2009, 03:53 PM
jasonlx's Avatar
do you have your crankcase vented? mine does it when i drive hard because i dont have enough crankcase ventilation(pushes out the rear main). if i drive it easy(no boost) it doesn't do it. i might actually fix it one of these days, lol.
93 lx, stock block, windsor jr. heads, custom cam, track heat , 75mm tb, hellion turbo kit (62-1), abaco 85mm, PMS IV, 3:27's, t5
proud member of the "jackstand turbo mustang club"
jasonlx is offline
post #4 of 4 Old 08-19-2009, 09:33 AM Thread Starter
87pony's Avatar
I have a filter on one valve cover and an open tube on the other right now. Still does it. Maybe it just screwed the rear main up enough before I vented the driver's side.
87pony is offline
odd head gasket leak? d347643 5.0/5.8 Engine Tech 1 08-04-2009 02:21 AM
Vacuum Leak: Common Kenne Bell Leak Locations?? Nick Davidson Superchargers 11 06-07-2007 08:20 AM
Odd noise... sounds like an exhaust leak, but isnt. OF94gt50 SVT & DOHC 10 12-11-2005 12:36 PM
Ford parts guys here? Cant find the right power steering hose. Help! Leak...leak. gruvee87vertgt General Mustang Tech 2 08-01-2005 02:43 AM
Narrowing the problem (I think), coolant leak in odd place, please take a look... Chris Doss SVT & DOHC 4 10-22-2002 08:17 PM
