Any thoughts on M-6051-B51 head gaskets?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-16-2009, 11:08 PM Thread Starter
CaliNotch n MI's Avatar
Trader Feedback: (15)
Anyone running these??? http://www.summitracing.com/parts/FMS-M-6051-B51/
I blew a head gasket over the weekend, thats the 2nd set of 9333 that I've been through.....
1993 Notch: Mexican 347 Hellion TFS heads/GT40 intake/Custom Cam Tremec 3550
1992 GT Convert: Green/Blk interior, 10th anniversary cobra's mostly suspension mods.
FB users please, PLEASE click "like" button. Thanks!!
CaliNotch n MI is offline
post #2 of 3 Old 08-17-2009, 08:19 PM
red89coupe's Avatar
Trader Feedback: (31)
IF your blowin gaskets like that something is wrong !! I have run them for years without issue.
blowin gaskets is usually a tune issue, putting in a stronger gasket is just gonna make it worse. are you SURE your heads are FLAT??
HGs are a fuse.. you use too big of a fuse you end up with a fire.
red89coupe is offline
post #3 of 3 Old 08-19-2009, 03:21 PM Thread Starter
I did put a straight edge on it and it looked to be pretty true... might send them out just to be on the safe side.
Head gakets 8548pt-2 compared 6051-b51 Brian 90 5.0/5.8 Engine Tech 0 05-27-2006 03:27 PM
Ford 6051 B51 gaskets changed? Stang94GT 5.0/5.8 Engine Tech 0 03-03-2005 03:22 PM
HELP!!!!!!!!!! M-6051-B51 FRPP headgaskets.Which way up??????? 86caprirs 5.0/5.8 Engine Tech 4 09-02-2003 08:42 PM
6051-B51 gaskets dman344 Turbochargers 6 01-26-2003 12:54 PM
anyone ever used graphite head gasket? part # M-6051-B51 white94 94/95 Tech 2 07-04-2002 02:41 PM
