Please help with ponydown kit on 351w in a coupe - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 08-16-2009, 01:19 PM Thread Starter
Trader Feedback: (-1)
i have 1 351w in a 90 coupe that i have installed a hotside stage 2 kit from ponydown and need some pics of the setup if you have the same kit or something similar. I bought a mpt76 turbo and believe i need to rotate it. Is it as simple as removing the bolts from the compressor and turning it? and there is no room to put any kind of air filter on the front of the turbo what did you guys do for that? pics of your setup would be very helpful. I will be building the coldside piping myself. Should i use 2 1/2 inch or 3" pipe for that. i am looking for around 750hp on pump gas.thanks for any help
0402vette is offline
post #2 of 2 Old 08-18-2009, 07:20 AM
Trader Feedback: (18)
i used 90* silicone adapters to turn it into the fenderwell. had to enlarge the hole. pony down has a filter that will fit on the housing where he positions the turbo. its not very long, maybe 3"
Tony K is offline
ponydown twin turbo kit in nj 2500 miles 88twinturbostang Power Adders 5 03-18-2009 02:44 PM
Ponydown turbo kit 2002mustanggt GT & SOHC 11 06-04-2008 03:01 AM
Ponydown TT kit??? slowblown5.0 Turbochargers 5 09-22-2006 08:28 PM
700rwhp on pump gas with Ponydown stg3 kit!!!!! chris123 Turbochargers 22 06-12-2006 10:33 AM
Is anyone running a twin turbo kit from ponydown.net?? RGVBadBoy Turbochargers 8 05-06-2005 03:52 PM
