compression? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 08-16-2009, 04:41 AM Thread Starter
Blame Canada!!!!!! I FAP for CANADA!
fapperDan's Avatar
Trader Feedback: (44)
compression?
What is the highest compression I can safely run? I have a long block with forged flat tops with 4 reliefs and 61cc chamber heads. thinking that would put me at about 9.5 to 1 or slightly higher. can i put a thicker head gasket on it and bring the compression down or would that be ok? I'm only going to run 10-12 psi max.
Banned!!!!!!!!!!!!!!!!
Canada loves me this I know, Cause the "Don" tells me so! Tumbleweeds we sell all day long, Ghost towns are coming so stay strong!
fapperDan is offline
post #2 of 5 Old 08-16-2009, 08:07 AM
Trader Feedback: (36)
9.5:1 will be fine......Its ultimately going to depend on your tune and how close you get it .
scotng is offline
post #3 of 5 Old 08-16-2009, 09:38 AM
BradleyRJ's Avatar
Trader Feedback: (25)
9.5 will be fine for a street toy / weekend play ride that isnt going to see a lot of boost ( < 12lbs...) Just make sure the tune is good and you'll be fine. Run good gas.
They say what goes up must come down but I ain't reached my cruising altitude.
Take a look at what I did but can you imagine what I'm about to do.
BradleyRJ is offline
post #4 of 5 Old 08-16-2009, 09:58 AM
9.5 is fine.
It's all in the tune .............
A good intercooler to lower air intake temps will help a LOT too.
It's not the boost, but the heat for the boost, that causes detonation.
r.barn is offline
post #5 of 5 Old 08-16-2009, 06:23 PM Thread Starter
fapperDan's Avatar
Sweet, thanks guys. I didnt want to have to teardown my shortblock if i didn't have to.
high compression vs low compression on a boosted modular 99GTC SVT & DOHC 183 02-18-2013 03:49 PM
High compression 306 9:4:1 vs low compression 347 8:3:1 pcharged93 Superchargers 0 09-13-2005 04:05 AM
High compression combo- Compression vs. Ignition Timing Beef Curtains 5.0/5.8 Engine Tech 27 12-04-2004 06:05 PM
Does a compression test give you the overall compression of engine or just cylinder? 92StangMan General Mustang Tech 1 02-10-2004 01:18 AM
High Compression or Low Compression 347?? Help me decide!!! Blown302stng 5.0/5.8 Engine Tech 7 09-26-2003 06:58 AM
