Set up help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 08-14-2009, 01:29 PM Thread Starter
Set up help
Ok I just picked up a an all forged 351 lightning roller block, with an e cam. My goal is to push the block to it's limit.
This all will be going in a 85gt, going to stay carbrated.
would like to know how big a cfm blow thru carb I would need?
The heads I plan to go with is a set of dart, Roush, or something Iron with 202/ 160's
Need to know whats a good single plain intake?
and what jetting for the Carb? (this will be my first ever carb forced induction setup) tired of High tunning cost.
What size single turbo? is there a size between the popular 76 and 88 trim turbos
what would be the best fuel system?
98blowngt is offline
post #2 of 2 Old 08-17-2009, 07:51 AM
ssj50driver's Avatar
I am trying not to be "that guy" but man you have to have some of these questions at least spread out. Granted I have not looked over your other threads you may or may not have posted. I would say on a stock displacement 351 a 76 has more than enough potential to split that block. There is a lot of information over on turbomustangs if you search or check in the newbie tech. Why not do a set of twin turbos from a thunderbird? If you can weld your own stuff that is a cheap and neat way to make power in my opinion. Fuel system, I cannot help you there unless you use electrical. On the car stuff I totally suck. Hope it all works out for you.
ssj50driver is offline
1 set of Pony wheels, 1 set of Cobra R's ($100 per set) sapphire95gt Rims Wheels and Tires 3 11-11-2008 04:07 PM
'87-'93 SALEEN KONI STRUT & SHOCK SET!!! $199.99/set!!! mustangparts Suspension 2 09-18-2005 07:32 AM
WTB A Set of Hooker Headers for TFS R Head 351W or a set of Kooks!! Codeblue393gt Exhaust Parts 1 04-29-2005 12:53 AM
FS: front set of Steeda Sportline & full set of stock springs gideup Suspension 3 03-25-2005 05:10 PM
How To Set UP PCHow To Set UP PVC tube with power-pipe & bypass mlb585 5.0/5.8 Engine Tech 0 04-26-2002 10:43 PM
