looking 4 pics of homemade single turbo 5.0's + more - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 08-09-2009, 05:25 PM Thread Starter
rab
and any other info about odd problems you guys have ran into fitment wise.
im looking to do a homemade single turbo set-up on my 82 fairmont,
stock 87 5.0 ho with a 5 speed and a maf converion on a speed den. hanrness with a custom tune.
i will probably just flip the stock headers and run a holset or something decent sized that i can pick up used to get keep cost down.
im not looking to put down crazy numbers just around 350-400.
rab is offline
post #2 of 15 Old 08-10-2009, 03:19 AM
Trader Feedback: (36)
My build on Turbomustangs.com........You'll have to register to see the pics. They have a very extensive Do It Yourself forum.
http://www.theturboforums.com/smf/in...?topic=83067.0
scotng is offline
post #3 of 15 Old 08-10-2009, 09:15 AM
H1E was $100 off ebay (lucked out there as it was still good)
Hotside to turbo - one $20 2.5" u-bend and the rest was scrap from the shop I worked at
Downpipe - $120 or so for the v-bands, 4-3.5" reducer and two 3.5" u-bends.
streetfalcon is offline
post #4 of 15 Old 08-10-2009, 07:13 PM Thread Starter
rab
does anyone retain the front swaybar and powersterring in there homebrewed turbo set-up, im sure you can and i want to, but it seems like everyone does not.
rab is offline
post #5 of 15 Old 08-10-2009, 08:47 PM
Most of the people getting rid of this stuff are running a drag only car, or a car the is straight line, drive it once in a while type cars.
You can easily build a setup that retains everything but the smog equipment. That stuff is hard to keep, although it is not impossible. If you have to deal with a tough I/M state, then be very careful what you take off.
Zeet's5.0 is offline
post #6 of 15 Old 08-10-2009, 09:29 PM
My kit retained everything.....A/C, power steering, sway bar. Everything except the smog pump.
scotng is offline
post #7 of 15 Old 08-10-2009, 09:34 PM
There's plenty of room to keep all accessories and sway bar using flipped shorties.
Running the a/c lines to the condenser gets a little tricky, but
you can make custom lines easy from online suppliers. All the fittings
and hoses are universal.
r.barn is offline
post #8 of 15 Old 08-10-2009, 11:56 PM Thread Starter
rab
no emisions for me and i won't be running a/c either.
rab is offline
post #9 of 15 Old 08-12-2009, 12:47 AM Thread Starter
rab
anyone have pics?
rab is offline
post #10 of 15 Old 08-12-2009, 02:07 AM
here are a couple of my 0.2.1 build while still in construction. I went with a simple log construction because I am using P heads and none of the shorties I have work.
odd problem: If building and wrapping headers, be sure to leave enough space to remove the spark plugs; I did not, so my next revision will include adjustments to the primaries/logs to allow plug changes without removing the headers.
I still have my front anti-roll bar (visible in second pic) but I do not have power steering (car had a manual rack when I bought it).
Pope is offline
post #11 of 15 Old 08-13-2009, 08:05 PM Thread Starter
rab
cool, keep posting them up.
rab is offline
post #12 of 15 Old 08-20-2009, 12:48 AM Thread Starter
rab
anyone else?
rab is offline
post #13 of 15 Old 08-20-2009, 08:15 PM
lechols155's Avatar
not fully done mine but i will post as soon as it is
92 gt
Old setup: 100% stock w/ turbo 10.80 @ 126
lechols155 is offline
post #14 of 15 Old 08-20-2009, 09:41 PM
i cant post pics for some reason
negozio is offline
post #15 of 15 Old 08-21-2009, 06:23 AM
Rich G's Avatar
Trader Feedback: (35)
you gotta have more posts
Rich G is offline
homemade single turbo kit will support 1000hp platedturbonotch Power Adders 16 09-18-2005 11:22 PM
WTB....single or twin turbo kit complete. (nice homemade kits OK) frank woodall Power Adders 0 05-21-2004 06:37 PM
94 GT single turbo setup ( pics) poostang Turbochargers 29 01-05-2004 05:09 PM
How to Homemade Cold Air For 5.0's makuloco1 5.0/5.8 Engine Tech 0 05-28-2002 09:06 PM
HOMEMADE TURBO kits/ can I see your pics or web pages! PH112 5.0/5.8 Engine Tech 1 03-17-2002 09:39 AM
