Do i have to have a rising rate AFPR? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-08-2009, 03:15 PM Thread Starter
PurpleGT's Avatar
I currently have a paxton on my turbo car, but i believe its starting to leak fuel a bit out the vac side... Only seems to raise the rate .5:1, give or take. I have a holley on my other car, could swap that over? Money is a bit tight, and i would like to get this thing back together is all. Thanks guys.
Ill be running 42s on my stock 5L with GT40's, cobra intake, e cam and 9-12PSI.
Brian
-1982 Mustang GT, T5, 3.73s, EFI'd 408W, soon to be parted and retired
-1991 Notch, numbers matching 2.3l auto, all motor!
-2003 DSG Cobra, 2.8, intake, exhaust, tune, basics.
PurpleGT is offline
post #2 of 4 Old 08-08-2009, 04:14 PM
red89coupe's Avatar
Trader Feedback: (31)
you HAVE to run a boost ref regulator !!
IF you cant afford a aftermarket one find a cheap stocker, its not adjustable but it is boost ref
red89coupe is offline
post #3 of 4 Old 08-09-2009, 01:46 AM
foxfan88's Avatar
Yes to do it right you need to have a rising rate regulator that is 1:1. and a stock regulator does just that.
If you dont have one and go under boost, your injectors will flow less fuel per given PW and you will lean out. I suppose if you had other means to increase PW to compensate for the lower flow rate, you could get the AFR back in check but thats a HACK and far from the way it needs to be done.
Brett
91 GT 302 CID c4 w/brake
TFS TW heads, f-cam, typhoon
70mm masterpower single turbo setup.
foxfan88 is offline
post #4 of 4 Old 08-09-2009, 05:44 AM Thread Starter
PurpleGT's Avatar
Okay, stock one it is then. Pretty sure this paxton has leakage
Thanks guys. Wasnt sure if the holley adjustable i put on my other car was usable or not. Doesnt seem to be from reading anyways.
PurpleGT is offline
Bell Engineering FMU (Rising Rate Fuel Management Unit) s8v4o Fuel System & Related 1 10-29-2007 01:04 PM
Cartech rising rate FMU chxdigt Power Adders 2 07-27-2007 10:14 PM
Trouble converting stock location spring rate to coil over rate? Torque / Panhard Mr. Kelley General Mustang Tech 1 03-17-2005 12:39 AM
New BEGI Rising Rate FMU c.m.perry Fuel System & Related 2 01-06-2005 07:47 PM
03 Cobra dampers...coupe rate verses vert rate? TxSnakeCharmer SVT & DOHC 51 10-07-2002 12:37 PM
