swap to stock cam from F-cam? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 08-08-2009, 01:42 AM Thread Starter
foxfan88's Avatar
I parked my mustang for the turbo build. I started tearing a few things down checking some things. Something in the back of my head was telling me to pull my heads off...
Pulled my heads off and found a chamber with the valve seal all burnt/chewed up b/w the valves (thinnest part where the two valves almost meet) The plug in this cylinder also had the ground strap burnt or broke off (didnt look at it close enough)
Needless to say thats going to have to be fixed, i am going to pull the motor again since the rear main leaks and i am going to inspect the bearing related to another issue.
I got to thinking about swapping back to a stock cam and a performer intake and keeping my TW heads. I like the idea of a tame stock idle and the well mannered/smoother driving of a stock cam.
The way i am seeing it... The turbo i am going to use (mpt70) can push more than enough air to split the stock block, so why not have the smoother idle and better manners driving around while i am at it. If i have the ability to easily split the stock block regardless of cam choice them it would seem to make sense... Plus a stock cam would make more low end and it would keep the RPM band down promotoring more longevity out of the engine.
Just trying to get some idea and input from people running the stock cam or have done similiar swaps. I'd like to do it, but i keep thinking maybe it would be a step backwards, i'm not wanting to kill power, just shift the powerband down some....
Brett
91 GT 302 CID c4 w/brake
TFS TW heads, f-cam, typhoon
70mm masterpower single turbo setup.
foxfan88 is offline
post #2 of 9 Old 08-08-2009, 01:49 AM
badloser's Avatar
Trader Feedback: (53)
a stock cam and a 70mm turbo will make tons of hp. I say you are right enjoy the smooth idle and turn up the boost when you want to go fast.
badloser is offline
post #3 of 9 Old 08-08-2009, 01:14 PM
Trader Feedback: (43)
My F cam is pretty much like a stock cam driveability wise and its ####ing mean.
Precision 67mm turbo, this and that.
Thewhite88pony is offline
post #4 of 9 Old 08-12-2009, 01:32 PM
Blame Canada!!!!!! I FAP for CANADA!
fapperDan's Avatar
Trader Feedback: (44)
Sorry to highjack but how would a b cam work with a turbo?
Banned!!!!!!!!!!!!!!!!
Canada loves me this I know, Cause the "Don" tells me so! Tumbleweeds we sell all day long, Ghost towns are coming so stay strong!
fapperDan is offline
post #5 of 9 Old 08-13-2009, 12:11 PM
Steed93's Avatar
I still use the stock cam and it idles pretty smoothly once it gets warmed up. It also has good drivability. Get a chip burnt and it will drive just like stock.
1993 LX hatch
11.21 @ 124
480 whp, 520 wtq (10 psi)
Steed93 is offline
post #6 of 9 Old 08-13-2009, 08:47 PM Thread Starter
foxfan88's Avatar
I tune my car with a QH, my idle is pretty good as well as the drivability....i'm more leaning towards the lower powerband and the sleeper effect...
Brett
foxfan88 is offline
post #7 of 9 Old 08-13-2009, 09:33 PM
jturmanator's Avatar
Mine runs great with stock cam. Makes power till about 5400 rpms then falls of.
jturmanator is offline
post #8 of 9 Old 08-14-2009, 10:13 PM
millhouse's Avatar
I was conteplating the same (I even have 1.7rr's on top of it)...but if your idle is good and your happy with it, why switch? With the f303 you can still shift at mild rpm's (6k and below) without hurting performance. It will also allow you to run less boost while making more power.
As for performance, the stock cam may feel more peppy down low on the street...but the "F" is going to give you better numbers at the track. I say keep it as it is and get some solid numbers. If your still not happy, swap it out for stock and get some new numbers (and keep us updated).
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #9 of 9 Old 08-15-2009, 06:53 PM Thread Starter
foxfan88's Avatar
I think i decided to go ahead and stick with the F and typhoon and see how it works with the turbo for now. I dont really feel like going through the hassle of finding a stock cam to use and 1.7s to go with it. If i feel the need to swap i can always do it like you said Millhouse.
Brett
foxfan88 is offline
Should I swap my cam back to stock? WhiTeFoX5point0 5.0/5.8 Engine Tech 7 10-01-2006 03:06 PM
stock cam swap?? mark88 SVT & DOHC 1 09-27-2006 11:01 PM
gt40 heads! e-cam, x-cam or stock cam and explorer or rpm intake? 5.0 Hatch 5.0/5.8 Engine Tech 6 11-04-2005 06:57 AM
Stock cam \w 1.7 rockers or swap to 2031? scarless 94/95 Tech 17 10-06-2004 03:15 AM
Do you change the cam bearings w/ a cam swap, can you do this w/ the eng. in the car? Fast90LXStang 5.0/5.8 Engine Tech 11 12-08-2003 11:29 AM
