Bg kit..need help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 08-05-2009, 01:59 AM Thread Starter
Djstorm100's Avatar
Bg kit..need help
I have a 3 inch cowl hood and mark 8 fan. I have 306 with a bg kit. Do I really need to heat wrap the downpipe? or will i'll be ok with it? I put some ceramic coating on it from advance auto/ autozone. and cured it but still haven't drove it or got it tune so I don't know how hot it will get under the hood. Its still on jack stands, needs a few more things completed before I take it to get it tuned.
Djstorm100 is offline
post #2 of 16 Old 08-05-2009, 04:04 AM
Trader Feedback: (45)
It will be fine. Invest in an aluminum radiator before you wrap it up.
1989 Ford Mustang Notch 5.0
1979 Ford Fairmont Boxtop (LSX/4.8/Big BW Turbo)
Speedy911 is offline
post #3 of 16 Old 08-05-2009, 04:43 PM
pennex1's Avatar
Do yourself a favor. Wrap it! I have the BG kit with the coating they put on. The coating does not keep enough heat from radiating in the engine compartment. A ended up wrapping everything except the header tubes. You will also definitely need to get a turbo blanket. It will make night and day difference. Wrap any wires or fuel line that is anywhere near the turbo pipes.
Dart 347, High Ports, FAST XFI, TH400, Precision 78GTS,E85, 836hp 714tq.
pennex1 is offline
post #4 of 16 Old 08-05-2009, 05:17 PM
Trader Feedback: (36)
Everything he said...........
scotng is offline
post #5 of 16 Old 08-05-2009, 08:21 PM Thread Starter
Djstorm100's Avatar
I have cermaic coating.. i dont have the paint that they put on there.
post #6 of 16 Old 08-06-2009, 05:54 AM
Rich G's Avatar
Trader Feedback: (35)
I have the BG ceramic coated kit, and even with wrapping it gets hot as hell. Wrap is fairly cheap so I would do it.
Rich G is offline
post #7 of 16 Old 08-06-2009, 08:20 AM
93gtman's Avatar
Trader Feedback: (21)
i had my whole kit ceramic coated not from b&g but from jet hot...and i also wraped the downpipe and the crossover and have a turbo blanket...i would do that and wrap any nearby wires or fuel lines like above
NY
93gtman is offline
post #8 of 16 Old 08-06-2009, 10:28 PM
Trader Feedback: (23)
Does the wrap or blanket cause any warranty issues with B&G? I've had cracking issues with an old turbo setup on a srt4 caused by header wrap on mild steel.
ruffian is offline
post #9 of 16 Old 08-06-2009, 10:52 PM
do your self an even bigger favor and give swain tech a call get their white lightining coating. then the only wraps you will have to worry about is what you want for lunch. have it on my car and is cooler under hood than when stock.
http://www.swaintech.com/store.asp?pid=10969
plus it looks sick(i think)
blackgt40notch is offline
post #10 of 16 Old 08-07-2009, 05:32 AM
Rich G's Avatar
BG only wants you to wrap the dp, everything else voids warranty
Rich G is offline
post #11 of 16 Old 09-01-2009, 06:38 PM
Radrick50's Avatar
Trader Feedback: (60)
I'm not even going to fathom a guess as to how much that coating costs....
93 Notch 347 twin 66s TH400...8.54 @ 162 Radials
91 Notch 410W Novi 2000 5 speed...10.99 @ 136
Radrick50 is offline
post #12 of 16 Old 09-02-2009, 03:00 PM
Really? Surprised that a blanket on the turbo would void the warranty since that is so common place on all tang kits that I was surprised see the kit did not include one.
post #13 of 16 Old 09-02-2009, 03:12 PM
I think he's talking about the wrap. Based on their response, I wrapped my DP and nothing else.
'91LX Vert- Stock Shortblock, Stock Cam, Cobra Intake, Edelbrock Performer 1.9's, 42#er's, PMAS 3", AOD, 3.27 gears, B&G 70mm Single, 3500lbs w/ me
Best 1/8- [email protected] with a 1.64 60'
Best 1/4- [email protected] with a 1.66 60'
Funniest 1/4- [email protected] LOL
Doug Hatton1 is offline
post #14 of 16 Old 09-02-2009, 03:22 PM
I dunno, he quoted this when he said it, which is why I asked:
post #15 of 16 Old 09-02-2009, 03:35 PM
Radrick50's Avatar
Lightbulb FYI: Swain Tech Ceramic coating Prices
I called them this morning to get a price estimate for my BG hotpiping:
Both headers: $300
Cross over: $100
Turbo exhaust housing: $100
Down pipe: $150
Total: $650
It looks like nice stuff, but I can't afford that kind of money...I'll stick with Inferno heat wrap...it's good for 2000 deg continuous and 3000 deg intermittent...$100 for a roll of 2" x 50'. I've heard that this stuff doesn cause as many issues with metal fatigue and cracking as the cheaper wrap??
post #16 of 16 Old 09-02-2009, 10:59 PM
I never wrapped mine, it gets hot, but so far no problems.
L&StangNC is offline
80mm turbo kit + alum rad. made for kit 2200 plus ship! boosted66 Power Adders 15 11-28-2008 07:18 PM
FS nitous works 70mm 5.0 plate kit brand new, full kit $375 Blazin1320 Power Adders 5 08-15-2007 06:37 AM
New NX Express kit for 99-03 +Accessory Kit II + Double Purge Kit mrhack Power Adders 5 09-15-2004 01:30 AM
429 460 Swap kit into Fox Body Complete Kit Less Headers!!! itow 351C/BBF Parts 8 03-08-2004 08:27 AM
