Upping the boost 4lbs , how much timing should I take out. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 08-03-2009, 03:32 PM Thread Starter
brian15's Avatar
current .... stock motor , 62mm , 10psi and 93 oct gas ..... running at 22* total and in high gear it see 11.0 afr.
boost will be set at 14lbs with all other items remaining the same save for 110 octane....... would 18* be a safe place to start ?
im really trying to get 10.50's out of this thing
brian15 is offline
post #2 of 15 Old 08-03-2009, 06:27 PM
red89coupe's Avatar
Trader Feedback: (31)
whats up man??
what are you tunning with ?? or are you running locked timing ??
Im still un-tuned running 8* spout IN , but Ive upped it to 14psi on 94 oct pump gas. I have NO clue the TOTAL timing tho lol
I think 18 MIGHT be a little low but better to start too low thwn too high lol HG's will thank you lol
red89coupe is offline
post #3 of 15 Old 08-05-2009, 07:30 AM Thread Starter
brian15's Avatar
Originally Posted by red89coupe View Post
whats up man??
Im running the timing locked out at 22* ... i took the car out last nite and it looks like it makes 13psi or so.
I left the timing the same and added 5lbs of fuel pressure , when i took the car out for a few brief high gear pull its was like 9.8 afr so i need to lean it out still.....kinda weird since i left the timing the same.
brian15 is offline
post #4 of 15 Old 08-09-2009, 01:14 AM
Why would you add 5 lbs of fuel pressure?
1965 Cobra replica with twin turbo Dart block 331
thomaswpt is offline
post #5 of 15 Old 08-09-2009, 06:40 PM Thread Starter
brian15's Avatar
too make sure the car didnt lean out with the added boost .
wensday night the car went 10.85 at 126 on 13psi
brian15 is offline
post #6 of 15 Old 08-09-2009, 10:21 PM
What is your target a/f? Is it still going to be 11.0?
- 89 Turbo coupe
-2003 10th Cobra -Gone
-1995 Mustang GT Vert-stock- Gone
forbanger is offline
post #7 of 15 Old 08-10-2009, 11:34 AM
The reason I asked why you're raising your fuel pressure is that your regulator should increase the fuel pressure automatically with each lb of boost. Cheers.
post #8 of 15 Old 08-10-2009, 11:44 AM
93gtman's Avatar
Trader Feedback: (21)
18 would be safer if you ask me. are you running stock heads or somthing else?
NY
93gtman is offline
post #9 of 15 Old 08-10-2009, 12:37 PM Thread Starter
brian15's Avatar
yea i try to aim for the low 11's ....but seems like 11.0 is where it always ends up
brian15 is offline
post #10 of 15 Old 08-10-2009, 12:37 PM Thread Starter
brian15's Avatar
good point that did not even come to mind ! ...thanks
brian15 is offline
post #11 of 15 Old 08-10-2009, 12:38 PM Thread Starter
brian15's Avatar
timing was left at about 21* on 93 octane and the afr stayed in the low 11's on the top end of the track.
yes stock heads with arp head bolts!
brian15 is offline
post #12 of 15 Old 08-10-2009, 02:18 PM
93gtman's Avatar
as long as you dont hear any ping you should be fine in the low 11's or just flat 11.0
NY
93gtman is offline
post #13 of 15 Old 08-21-2009, 01:25 PM
did you ever hit a 10.50?
noslow_306 is offline
post #14 of 15 Old 08-21-2009, 02:13 PM
strokercharged95GT's Avatar
not only that but the more boost will register in the MAF causing the injectors to richen aswell, assuming you have enough injector, base fuel pressure, and the MAF isnt pegged.
2013 Mercedes GLK-350
strokercharged95GT is offline
post #15 of 15 Old 08-22-2009, 03:48 PM
Mustang_mikeX's Avatar
I used to hear that for every pound of boost, retard the motor 2 degrees. Not sure if this a good rule of thumb or what.
Thanks, Mike
94 GT w/ 306, GT-40 irons, 94 Cobra Intk, E303 Cam, 70mm TB, Fluidyne radiator, Equal length headers, Magna Flow Exhaust, subframes, upper and lower control arms, 3.27 gears.
Mustang_mikeX is offline
Upping KB Boost =new tune? Haggis13 Superchargers 6 07-08-2009 10:40 AM
upping the boost JTsStang Superchargers 5 01-07-2009 11:37 PM
Upping the boost on 94 gt... help boooost94 Superchargers 3 07-24-2006 02:46 PM
Loosing boost over 4lbs or WOT w KB WHY???? Ssstang67 Superchargers 16 09-03-2003 01:20 PM
When upping the boost do you have to... Pete361 GT & SOHC 11 04-22-2003 12:52 AM
