Going from 3.55's to 3.27's.... general questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 08-02-2009, 11:17 AM Thread Starter
I have a question. My car has 3.55's and the mph is unusually low for my setup. I haven't used the 2-step yet, but am hoping this makes a huge difference. I see all of these cars running 118-120 or so with the same power my car's making. So far, I have it narrowed down to a few potential culprits. It may be ONE or ALL of these affecting the times. Again, I'm not near as interested in lack of ET as I am MPH, although I'm beginning to think on an auto turbo car, they're one in the same. So far the best the car has done in the 1/4 has been a 12.8 @106 @ 12#'s with a 1.92 60'. The car has a fresh built AOD and a TIGHT converter. I can only get to about 2000 rpms before it tries to powerbrake. Now, I KNOW that the tight converter is hurting my launch. But the other thing I'm concerned about is the lack of mph between the 1/8th mile mark and the end of the 1/4. The car only picked up 21mph. Seems REALLY low. As far as the tune, I've had 2 different dyno sessions and the car is making the power. @ 12#'s it makes 420/450tq. That should get me close to 120 in the 1/4 @ 3550 lbs.
SOOOO, the things that I think are contributing are:
Converter too tight? Need to get closer to 2800 rpm or so on the footbrake?
Need to get into boost sooner (read converter, or 2-step)
Need to launch on 2-step (BTW, I got it wired up and can make 2#'s @2000rpm.
Will going from 3.55's to 3.27's help "load" the car better and result in better mph?
'91LX Vert- Stock Shortblock, Stock Cam, Cobra Intake, Edelbrock Performer 1.9's, 42#er's, PMAS 3", AOD, 3.27 gears, B&G 70mm Single, 3500lbs w/ me
Best 1/8- [email protected] with a 1.64 60'
Best 1/4- [email protected] with a 1.66 60'
Funniest 1/4- [email protected] LOL
Doug Hatton1 is offline
post #2 of 10 Old 08-02-2009, 11:37 AM
Whats your 1/8th mph?
JBIGBOOTSY is offline
post #3 of 10 Old 08-02-2009, 02:21 PM
ratedz's Avatar
I went from 11.30's-11.70's at 118-122 w/ 3.73's and no 2 step
to
10.50'[email protected] with 3.27 and launching with a 2step
1986 Mustang GT
525hp/626tq
ratedz is offline
post #4 of 10 Old 08-02-2009, 04:03 PM
2002mustanggt's Avatar
to
WOW, good times there.
2002mustanggt is offline
post #5 of 10 Old 08-02-2009, 09:57 PM
hmm..
I yhave 4.10's in my car. When I install the gears the car felt slower Alot. Now Ive got my turbo kit that will be going on wednesday. Do u guys think I need to put the stock gears back in?
nbatchler is offline
post #6 of 10 Old 08-02-2009, 10:08 PM
I got 3.73 but want to put back 3.27 as I have head it's the best gear and help spool faster cause of load. 4.10 is just way too low gear for turbo car and you woun't be enjoying boost cause it will go by fast.
post #7 of 10 Old 08-02-2009, 10:14 PM
My question is will it be faster with the 4.10 gears until 120mph or slower?
post #8 of 10 Old 08-03-2009, 11:00 AM
Slower I will say plus you might run out of 4th gear at the track. Forgot to ask what kit did you get? 5.0 or 4.6l ?
post #9 of 10 Old 08-03-2009, 07:28 PM
same kit as u!
post #10 of 10 Old 08-04-2009, 01:33 AM
same kit as u!
You going to f**king love it.
WTT: 3.27's for 3.55's 86 slo-vo Drivetrain Parts 1 12-23-2007 09:01 PM
3.55's or 3.27's? blue.coupe Drag Racing 4 12-09-2007 02:26 PM
3.27's or 3.55's Blackfive0 Turbochargers 6 09-27-2006 12:33 PM
3.27's or 3.55's? proboscis General Mustang Tech 22 03-26-2002 06:10 PM
3.27's vs. 3.55's?? 98-4.6GT GT & SOHC 28 03-14-2002 12:32 PM
