Turbo Intake Recommendation - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 07-26-2009, 05:34 PM Thread Starter
jimzilla's Avatar
I am in the process of building a 5.0 twin turbo street car and I need an opinion on which intake to use. The motor is a 331 stroker; victor Jr heads, 8.7:1 compression redline at 6200 rpm, 14-16 psi boost. I am looking to make 750-800 HP at the fly. I want a plenum type intake vs. a box type; although I have heard that the TFS Box R is good. I noticed that the N.M.R.A. guys are using a lot of Holley systemax-2 intakes on their turbo cars? What do you guys think? Thanks Jim.
jimzilla is offline
post #2 of 6 Old 07-27-2009, 10:36 AM
ssj50driver's Avatar
Why not an rpm2 intake to match your heads. I use it and it's a good intake. Good luck.
ssj50driver is offline
post #3 of 6 Old 07-27-2009, 11:14 AM
twofast's Avatar
systemax. period.
68 coupe
351W PT-88 E-98
700hp/643tq [email protected]
radials/street driven
twofast is offline
post #4 of 6 Old 07-27-2009, 12:13 PM
Steed93's Avatar
The Holley is probably the best, but they have port alignment issues. I bought mine backin in 2002, so maybe they fixed that. I had to add some epoxy to the roofs of the intake ports to match up to my AFR heads.
1993 LX hatch
11.21 @ 124
480 whp, 520 wtq (10 psi)
Steed93 is offline
post #5 of 6 Old 07-27-2009, 01:23 PM
Trader Feedback: (41)
RPM 2
X2
stangjumper is offline
post #6 of 6 Old 07-28-2009, 12:32 AM
The best choices are the Systemax and Rpm 2. You can't go wrong with either one.
1965 Cobra replica with twin turbo Dart block 331
thomaswpt is offline
GT40P Turbo Cam recommendation 302f150 5.0/5.8 Engine Tech 15 04-28-2009 11:30 PM
Intake Recommendation DK1994GTVert 94/95 Tech 6 02-09-2009 09:46 PM
Turbo recommendation diy budget build!!! kbturbo Turbochargers 4 12-13-2008 12:33 AM
Muffler recommendation for HP turbo 96 cobra eric hood Turbochargers 15 10-26-2007 06:20 PM
intake gasket recommendation own3d 5.0/5.8 Engine Tech 3 05-17-2007 11:25 PM
