On the dyno tuesday.. Questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 07-26-2009, 03:20 AM Thread Starter
Car is at the shop right now, had to work out soem cold start issues today so didn't get to run it so tuesday is the day.
What #'s should I be aiming for? I'd really love to hit 500 but it's through a C4 and it's 110 degrees in the summer here, so I'm thinking maybe I should just cap him off at 450 on 91 pump gas and be safe until it cools down and then try and run it for some bigger #'s. What do you guys think?
Car is a stock block H/C/I 70mm turbo car.
ChaseGT is offline
post #2 of 7 Old 07-26-2009, 08:55 AM
Rich G's Avatar
Trader Feedback: (35)
I would let the tuner handle it.
When I go to see my tuner I tell him what gas I want to use and how risky I want to be and he handles it. Hasnt failed me yet.
Rich G is offline
post #3 of 7 Old 07-26-2009, 08:29 PM
jturmanator's Avatar
It could make 350 hp on the dyno and run mid 10's!
Dont get caught up in the dyno numbers specially for an auto. I could only get mine to run 12.08 which to me is disapointing for 431 HP.
I had them tune for 93 octane then had them burn me a tune for some 110. Basically the 110 allows you to run more timing safely.
jturmanator is offline
post #4 of 7 Old 07-26-2009, 08:44 PM
ratedz's Avatar
I made like 416 or something close to that on a dynojet - thru an AOD and the car runs [email protected]
12lbs boost and I only run 93 octane gas.
As posted above, don't get caught up in the final numbers - they can be very misleading. Get a safe tune on the car and throw the dyno sheet in the trash, head to the track and post those numbers.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #5 of 7 Old 07-26-2009, 09:57 PM
Exactly who i was talking about, see I made more hp but my times are off a complete second and a half compared to Ratedz.
My favorite saying!
" I have never seen a dyno sheet win a race"
post #6 of 7 Old 07-27-2009, 01:44 PM
yes but your trap 117 mph... if I remember from your thread. 117 mph is good for a deep deep deep 11. You could even squeeze more mph in your 60' and go closer to tens.
19935.slow is offline
post #7 of 7 Old 07-28-2009, 06:00 PM Thread Starter
Ok well it was 115 degrees when we started the dyno runs, and only could muster up 410whp on 12psi, due to the heat... We did about 5 runs and heat soaked it and it lost 50whp, let it sit for 30 mins came back and gained it back..
Stupid Arizona..
On a side note, the car will prob still have plenty of power to run a 10 at the track considering it has a built C4 with a brake.
ChaseGT is offline
no spark need help going on dyno next tuesday blacksvt1997 SVT & DOHC 18 07-12-2008 06:02 PM
Dyno tune on Tuesday, Any guesses? lead09 5.0/5.8 Engine Tech 25 07-27-2006 10:22 PM
Going to the Dyno Tuesday.... JimsYellow88 Superchargers 19 09-03-2004 04:13 PM
Well i finally got dyno tuned tuesday lazer01cobra SVT & DOHC 8 02-21-2004 06:59 PM
