TT T3 5.0 manifold with external wastegate - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 07-25-2009, 11:41 PM Thread Starter
I cant seem to find anyone who makes a set of twin turbo manifolds for a 5.0 that are flanged for an external wastegate.
I was recently given a Garrett T04E(50 Trim) in trade for some time and parts. I was thinking of picking up a second one and TTing my 5.0 RX7, but I cant seem to find the manifolds I need.
btlfed7 is offline
post #2 of 10 Old 07-25-2009, 11:48 PM
jman511115's Avatar
That turbo might be a bit big for a twin turbo 5.0. Did you consider mounting them low and making your own extension pipe from the manifolds to the turbine housing?
64,999,987 firearms owners killed no one yesterday.
NRA member and you should be too! It's about more than just the guns. Join here.
https://membership.nrahq.org/forms/signup.asp?CampaignID=FrdmAssoc
jman511115 is offline
post #3 of 10 Old 07-25-2009, 11:54 PM Thread Starter
So its to small for a single, but to big for a twin....great
I would love to make an extension myself, but my welding sucks(I am getting better)
btlfed7 is offline
post #4 of 10 Old 07-26-2009, 09:03 PM
It's not necessarily too big for a twin. It depends on if it's a true to4 or if it's a hybred. a t3-4 in a 50 trim is still a pretty small turbo only capable of about 450 ish hp in single form at full tilt boogie. Twins would work very well but might not land in their effiency range for the boost level you want to run. If all else buy another and try it. If it dosent work there will be a line of 4cyl guys looking to buy them up.
hamstang is offline
post #5 of 10 Old 07-26-2009, 09:32 PM Thread Starter
It is a 50 Trim T3/T4 hybrid, not a true to4. I dont want to start shopping around until I can find someone that makes a set of T3 flanged twin manifold with external wastegates.
You say the turbo can handle 450ish HP? I am only shooting for about 300-350. But I was thinking this turbo would not flow enough to efficiently reach that in single form. Maybe my math was wrong, and I need to redo it.
btlfed7 is offline
post #6 of 10 Old 07-27-2009, 06:12 AM
millhouse's Avatar
Call Brian over at B&G and he should be able to hook you up with something.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #7 of 10 Old 07-28-2009, 03:36 PM Thread Starter
Do you have a website or contact number, my google fu seems to be weak on this one.
btlfed7 is offline
post #8 of 10 Old 07-28-2009, 03:56 PM
Get some $100 used BBK shorties and flip them around.
$180 cut-off saw and $300 mini-welder.
Just tac it together and take it up to let a good welder to finish.
It's incredibly easy to do
Twin's of what you have would be perfect.
Build kit up for cheap and have some cool tools left over
Can clue you into where to buy all the flanges and such.
r.barn is offline
post #9 of 10 Old 07-28-2009, 07:36 PM
millhouse's Avatar
http://bgturbokits.com/store/
post #10 of 10 Old 07-28-2009, 11:18 PM Thread Starter
I will look into that, and thanks for the PM
Thanks for the link
btlfed7 is offline
Who's running a vented external wastegate? 357poweredstang Turbochargers 25 08-08-2009 03:25 PM
FS: Turbo manifold, wastegate, blowoff valve, & injectors ALblown50 Power Adders 23 07-18-2009 10:13 PM
New 50MM external wastegate merc460 Power Adders 9 11-29-2008 01:22 PM
WTB: 96-98 KENNE BELL. OPEN HOUSE MANIFOLD. AND TOP MOUNT MANIFOLD. WHAT YA GOT? The Red Monster Power Adders 2 05-25-2008 11:00 PM
internal or external wastegate? 94cobra2615 Turbochargers 1 12-08-2003 01:38 AM
