Help with Boost On 347 w/10.5-1 Compression - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 07-23-2009, 01:43 AM Thread Starter
Hey there Guys! I Have the 95 with a Brand new 347 stroker, running 10.5-1 compression, I want to get this Boost Brothers turbo kit and slap it on her, Mabey get a few more ponies outa the old girl! So Do you think running 5-7 PSI on that engine would be a Bad idea... Im slowly learning here.. and this Forced Induction is a whold new ballgame!
Thanks for the help guys!
rjw347sn95 is offline
post #2 of 12 Old 07-23-2009, 05:54 AM
Rich G's Avatar
Trader Feedback: (35)
I ran 8 psi for a long time on a 306 w/ 10.4:1 and pump gas
I did end up lunching 3 pistons though.
I would sell the motor and put a stocker in their and then turbo it
Rich G is offline
post #3 of 12 Old 07-23-2009, 10:49 AM
Trader Feedback: (41)
Put a meth kit on it and run the SOB.
My friends 11:1 347 with 8 psi, 93 pump gas and meth ran a 9.5 @ 142 all day long.
stangjumper is offline
post #4 of 12 Old 07-23-2009, 11:09 AM
Trader Feedback: (18)
I'm almost done building a 347 with 10.4:1 compression and this is exactly what I plan on doing(blower not turbo). People will tell you its better to run lower compression with boost, and its true, it will give you a larger margin of error in your tune and allow you to run more boost safely. But by no means is it impossible to have a decent amount of compression while running boost. You can make more power on less boost with higher compression, you just need to watch your tune a bit closer. You can run a water/meth kit to spray only while in boost, and it will raise your octane level while lowering the air intake temps.
Idealy for turbo/supercharged apps, you'd want to lower compression and raise boost. Allowing you to make more power and keep the tune safe. But it can be done with your compression ratio.
justhereforinfo is offline
post #5 of 12 Old 07-23-2009, 01:06 PM
As long as you tuner knows what he's doing you should be fine running boost on top of 10.5 compression.... its all in the tune.
Nothing but slow chebby's right now.....
OrangeSVT03 is offline
post #6 of 12 Old 07-23-2009, 04:16 PM
AIS
My last Mustang was 10.25:1 compression running 10 psi non-intercooled S-trim on pump gas with meth. it's all in the tune.
AIS is offline
post #7 of 12 Old 07-23-2009, 04:39 PM
assasinator's Avatar
im running 8.5:1. BUT there are great upsides to higher, for get the tune. guys have that mastered. especially with a huge intercooler/and meth.
from where i sit. fuel is the big issue for turbo. BSFC's worse than .55 are common. you run a higher CR and sequeeze a LOT more out of the available fuel you wont join me and others who have to throw a freakin ton at it.
the other side of it is: if i upgrade the fuel theres a much higher limit for boost, and it will make up for the lower compression at some point.
96 mustang GT-93 teksid 4v forged: ported heads, kellogg crank, billet i-beams, CP forged pistons, 9.4:1, BIG turbo, 4x28x12 fmic, big boost.
2011 GT 300A, 3.73, M6, spoiler delete, brembos
assasinator is offline
post #8 of 12 Old 07-23-2009, 04:40 PM
its just a turn of the boost controller away.
post #9 of 12 Old 07-23-2009, 05:46 PM
That is mearly a BAND AID for people that cant tune or do a less than spectacular job at it.
Take it to a tuner that knows his stuff, let him take his time to dial it in and drive the car for a long time.
post #10 of 12 Old 07-24-2009, 08:00 PM
u lookin for an argument from me? you restated what i said, but did it implying you know something i dont.
i chose 8.5 for me. im not looking for every VE. instead i let boost do the job. its not a cop-out. ot a band -aid, go look for someone else to start crap with. the horsepower limit i set for myself can be exceeded easily with another 4 lbs.
i also detune it and run regular unleaded and get 31mpg. not going to do THAT with 10.5:1
post #11 of 12 Old 07-24-2009, 09:30 PM
strokercharged95GT's Avatar
im running just over 8 lbs with a 347 at somewhere between 10.5-11.0-1 compression. No matter what I did with timing and fuel i would get some pinging. I put a meth kit on it and havent had a problem since.
When I had procharger I could get away without the meth because of the linear boost curve, now with the boost slamming on theres no way to get around using meth.
2013 Mercedes GLK-350
strokercharged95GT is offline
post #12 of 12 Old 07-25-2009, 02:41 PM
+1, the higher the compression the motor the higher the octane needed to keep it safe. nothing wrong with running high compression with boost as long as you do it right
TWIN TURBO!! Because bottles are for babies and superchargers blow
megasquirt, 331, twin 66s, ported 205cc head, efi spyder intake, 160# injectors, e85
luckythirteen13 is offline
low compression high boost, hight boost low compression?? loudnslow98gt Superchargers 5 09-02-2007 05:54 PM
High compression 306 9:4:1 vs low compression 347 8:3:1 pcharged93 Superchargers 0 09-13-2005 04:05 AM
High Compression or Low Compression 347?? Help me decide!!! Blown302stng 5.0/5.8 Engine Tech 7 09-26-2003 06:58 AM
High Compression/Low Boost or Lower Compression/more boost? XSPOWER Superchargers 4 01-18-2003 07:49 PM
