For those running breathers on valve covers... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 07-21-2009, 03:25 PM Thread Starter
Arrow For those running breathers on valve covers...
What are you using to block off the old PCV port? I removed the gromet and tried using a rubbert radiator plug that expands as you tighten a bolt.. it works for awhile but then loosens and pops out.
What is the best way to do it?
I have breathers on both covers with lines to a vented breather.
ChaseGT is offline
post #2 of 10 Old 07-21-2009, 06:17 PM
Erich's Avatar
Sent it to another catch can vented to the turbo inlets.
Erich
Erich is offline
post #3 of 10 Old 07-21-2009, 06:35 PM
Rich G's Avatar
Trader Feedback: (35)
I tapped mine and installed a NPT plug
Rich G is offline
post #4 of 10 Old 07-21-2009, 08:17 PM
Trader Feedback: (22)
i just used a simple rubber cap to block it off...
LS1KILR is offline
post #5 of 10 Old 07-21-2009, 10:10 PM
I just caped off the PVC and left it in the hole.
Turbo 306,How fast will it go that depends on who is around.. Local parts pimp.. Things for sale most stuff is OBO https://docs.google.com/document/d/1hvqaA8aKICIw6BBj3IU2KCwiv86TtWXmxmvrsd8lw1A/edit?hl=en_US&pli=1#
wvstangdriver is offline
post #6 of 10 Old 07-21-2009, 11:53 PM
Trader Feedback: (41)
A mini K&N breather that fits right in the hole.
stangjumper is offline
post #7 of 10 Old 07-22-2009, 07:54 AM
Shanenindy's Avatar
x2
Shanenindy is offline
post #8 of 10 Old 07-22-2009, 07:57 AM
I put a freeze plug in and siliconed it so there would be no leakage. I use two breathers one for each valve cover.
kbscobravert is offline
post #9 of 10 Old 07-22-2009, 10:52 AM
87pony's Avatar
freeze plug
87pony is offline
post #10 of 10 Old 07-23-2009, 02:20 AM
PurpleGT's Avatar
Plastic elbow out of the gromet, heater hose to a catch can. May as well make use of it for extra ventilation.
-1982 Mustang GT, T5, 3.73s, EFI'd 408W, soon to be parted and retired
-1991 Notch, numbers matching 2.3l auto, all motor!
-2003 DSG Cobra, 2.8, intake, exhaust, tune, basics.
PurpleGT is offline
tall aluminum valve covers with breathers stang stupor Windsor Engine Parts 13 12-26-2008 10:45 PM
chrome tall valve covers breathers and gaskets mustangman50 Windsor Engine Parts 6 08-21-2008 04:58 PM
Well I just put breathers on my valve covers and I have a few questions greygoose 5.0/5.8 Engine Tech 1 11-14-2006 04:07 AM
valve covers with gaskets and breathers Lewis Windsor Engine Parts 6 10-17-2006 08:10 PM
Stealth crankcase breathers for 2V modular stock valve covers se2k GT & SOHC 3 10-13-2006 06:26 AM
