Wastegate leaking around the valve guide ?s. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 07-18-2009, 11:48 AM Thread Starter
It's not bad but I can till. Is this normal?
Thanks.
Stampede4ever is offline
post #2 of 2 Old 07-18-2009, 10:49 PM
93gtman's Avatar
Trader Feedback: (21)
there should be a ring that goes on in between the gate and the flange is that what you are talking about if that is not there it would cause an exhaust leak
NY
93gtman is offline
Explain the difference: Bypass Valve, Blowoff Valve, Wastegate Rich G General Mustang Tech 2 01-20-2008 10:51 PM
how much for a valve guide? JBR87 5.0/5.8 Engine Tech 8 10-11-2006 03:06 PM
broken valve guide ? RJH 5.0 General Mustang Tech 0 05-01-2006 09:51 AM
Valve Guide Specs? scarless 5.0/5.8 Engine Tech 0 12-14-2004 01:05 PM
How do you know if valve guide is bad? Daves94vert 5.0/5.8 Engine Tech 2 02-05-2004 01:21 PM
