V-Band flange question...how to straiten? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 07-17-2009, 11:08 AM Thread Starter
Ok, I got a hot side turbo kit with V-Band flanges...problem is, they look to have gotten too hot when welded to the collector and mating pipe and have warped. Is there a siple way to flatten that out or a suitable mating gasket that can handle exhaust heat?
I thought about using marking compound on a flat surface and taking a smooth wheel to it until it's pretty close and finding some sorty of cut your own gasket material. Ideas??
Thanks!
-Jonny
2012 Silver Mustang 5.0 Auto bone stock.
2000 Performance Red 4v turbo 545rwhp/570rwtq tuned by Andy "The Car Tuning Genius" (Prime-Tuning.com) - SOLD
Jonny00GT is offline
post #2 of 14 Old 07-17-2009, 01:50 PM
Cut your own gasket material will burn right up.. How bad is it?
ChaseGT is offline
post #3 of 14 Old 07-17-2009, 02:21 PM Thread Starter
Bad enough most guys with this hot side just weld the two faces together, but I think I may be able to pound it a little to get it closer to flat in a couple areas and use a grinder without the sheild flat on top of it to get a nice circumfrance level surface on both faces...not sure, but worth 15min of investigation if it means it comes apart for servising easier!
-Jonny
post #4 of 14 Old 07-17-2009, 03:17 PM
Trader Feedback: (41)
The problem is the V band clamps are designed with a taper to them. The tighter you make the clamp the closer the flanges come. Depending on how much you grind off might make a difference if the flanges will come together tightly.
stangjumper is offline
post #5 of 14 Old 07-17-2009, 03:48 PM Thread Starter
I thought about that...might also make enough room for some sort of a metal gasket, but if I don't grind, it's not going to seal anyway.
-Jonny
post #6 of 14 Old 07-17-2009, 05:29 PM
Worse comes to worse if it doesn't seal youll have just to cut the old flanges off and weld new ones on.
ChaseGT is offline
post #7 of 14 Old 07-17-2009, 05:55 PM
Shanenindy's Avatar
X2
That is what i was going to recommended. I actually had the same problem, and that is what i had to end up doing.
Shanenindy is offline
post #8 of 14 Old 07-18-2009, 06:11 AM
MIKE92NOTCH's Avatar
just take some 100 grit sand paper, stick it to a flat surface... then run the flat portion of the flange in a figure 8 pattern until it's smoothed out. it's typical for them to warp a little when welding.
i use a marker and color in the flange surface so i can tell how flat it gets all across
95 Crystal White GT
8.50 chassis with a 12 something drivetrain
MIKE92NOTCH is offline
post #9 of 14 Old 07-18-2009, 07:13 AM Thread Starter
That's a good idea...I'll give that a shot, thanks!
-Jonny
post #10 of 14 Old 07-18-2009, 08:42 PM
Mine were leaking just enough to put some soot around the clamps. The guys on turbomustangs told me to put a little high temp rtv around the flange. Did it. Worked like a charm.
87TurboGT is offline
post #11 of 14 Old 07-21-2009, 07:51 AM Thread Starter
You put it on the mating surface? Did you let it set up before tightening it all the way?
-Jonny
post #12 of 14 Old 07-23-2009, 06:51 PM
BAERSysteMAX's Avatar
Trader Feedback: (33)
touch them up with a belt sander. then use copper rtv on the flanges and tighten down the clamp.
90 lx 5 speed... 10.5 @ 136 stock bottom end and cam... ford junk !
86 gt ttop
90 coupe [email protected] turbo pump gas street car
BAERSysteMAX is offline
post #13 of 14 Old 07-25-2009, 09:12 AM
-Jonny
sorry for the late reply but no, i just put some on my finger and ran it around both flanges. i put it together right after. car may have sat a couple hours before i ran it though.
post #14 of 14 Old 07-25-2009, 10:04 AM
Rich G's Avatar
Trader Feedback: (35)
I put all my sealing areas together with copper RTV and have no problems
Rich G is offline
Can I buy 3" v band flange local? jturmanator Turbochargers 3 12-10-2008 08:57 PM
V band flange sizing question Tony K Turbochargers 0 04-12-2008 08:38 AM
Long tube question 3 bolt flange apecx 5.0/5.8 Engine Tech 3 02-25-2007 12:09 AM
v band flange Silverfox45 Turbochargers 1 04-30-2006 11:16 AM
Question about modifying a header flange Mike302 General Mustang Tech 3 10-10-2003 02:34 PM
