blown head gasket now what? and how much boost 5.0 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 20 Old 07-15-2009, 11:38 PM Thread Starter
ias97's Avatar
Trader Feedback: (61)
Just got my zoom clutch squared away and boom took out the passenger side head gasket, 60mm turbo, bone stock motor (19,000) anyway I am thinking cometic gaskets and studs, what do you think and how much boost can this handle?
ias97 is offline
post #2 of 20 Old 07-15-2009, 11:57 PM
Trader Feedback: (36)
Concentrate on the tune........How is it tuned?
scotng is offline
post #3 of 20 Old 07-16-2009, 12:52 AM Thread Starter
ias97's Avatar
it wasnt , it just went together
ias97 is offline
post #4 of 20 Old 07-16-2009, 01:55 AM
Trader Feedback: (157)
well um do u think that could be it?
do u have any way to monitor the a/f ratio?
tune it or?
if no to any of these then u need someone to tune it somehow..
jtmustang91 is offline
post #5 of 20 Old 07-16-2009, 06:04 AM
Boost without a tune... you'll be lucky if you havent melted a piston.
Nothing but slow chebby's right now.....
OrangeSVT03 is offline
post #6 of 20 Old 07-16-2009, 09:29 AM
Authorized corral.net Commerical Poster - Exp 4/2010
RealStreetPerformance's Avatar
Thats like getting someone pregnant your first time...
Basic rules are going to be,
1.remove a degree per pound of boost.
2.get the AFR under boost between 11-12.0
3. learn to listen to your engine, if it's hurting itself it won't do it quietly.
If you are green about forced induction, please slow down now and get your hotrod squared away before it becomes a fixture in the driveway or a huge headache.
Jay Meagher
Sales, Installations, Dyno, Fabrication, Engine Builds
850 N US HWY 17-92
Longwood, FL 32750
RealStreetPerformance is offline
post #7 of 20 Old 07-16-2009, 10:20 AM
I am with everyone else on the tune and good lord do not put cometic gaskets when using E7 heads. The gasket blew because it is the weak point and something was wrong that exposed that. Making the weak point stronger is not the solution at all because all that will do is make the next weak point break and the cost of repairs just keeps going up.
post #8 of 20 Old 07-16-2009, 03:27 PM
killacal's Avatar
I'm with everyone else on the tune....
But to anwser your orignal question I think that Cometics are a waste of money. I'm running Felpro's with ARP head Bolts, and they've seen 21psi a boost several times...
'89 Notch TT w/ custom tunes by Cal
killacal is offline
post #9 of 20 Old 07-16-2009, 06:08 PM
At minimal....set your timing to 8*, check fuel pressure and take it easy til you can tune it........I've got a chip for sale......find you a decent tuner and be done.
scotng is offline
post #10 of 20 Old 07-16-2009, 11:08 PM Thread Starter
ias97's Avatar
guys I agree about the tune, I understand, this thread was started about gaskets, this is not my first boosted car, it is however my first car that is bone stock with a little sleaper kit, use fel pro multi layer on my blower car and have had no problems, should I stick with fel pro
ias97 is offline
post #11 of 20 Old 07-17-2009, 06:42 AM
millhouse's Avatar
A 9333 or 8548 gasket can handle enough boost to push you past block splitting horsepower levels. A MLS or cometic gasket can do the same….although it won’t pop when you detonate. If you had ran them before without a tune, it’s possible that you could have popped a hole in the piston…or worse. Instead, here you are…inquiring about a gasket change….see where I’m going here?
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #12 of 20 Old 07-17-2009, 04:44 PM
Erich's Avatar
The felpros Millhouse suggested work well. ARP studs will be a nice addition as well.
Erich
Erich is offline
post #13 of 20 Old 07-18-2009, 07:53 PM
Snipe,
I haven't frequented this forum in a few years...didn't you used to have about 20k posts?
Did I miss something?
1990 Mustang GT, Explorer shortblock with DSS MSS, Edelbrock Performer RPM heads, stock GT cam with 1.72RR, ported Explorer intake and 65mm TB, PTK T66 kit @ 18psi, AEM EMS + WBO2, Alkycontrol methanol injection: All Sold
Cld12pk2go is offline
post #14 of 20 Old 07-18-2009, 08:40 PM
Originally Posted by Cld12pk2go View Post
Snipe,
I probably did on tm.com before one of the forum software changes but never over here.
post #15 of 20 Old 07-19-2009, 12:00 AM Thread Starter
ias97's Avatar
thanks guys , I should not of said how much boost can they handle, Yes I am curious however I relize a tune is what needs to be done.
ias97 is offline
post #16 of 20 Old 07-19-2009, 11:26 AM
lechols155's Avatar
geting readdy to do the same set up single turbo on a stock 5.0. getting bigger feul pump and injectors and trying to get money for a pms. what else should i get. dont have $$$ for heads so is it pointless to do an intake now?
92 gt
Old setup: 100% stock w/ turbo 10.80 @ 126
lechols155 is offline
post #17 of 20 Old 07-19-2009, 01:28 PM
I would save some money for things that might come up due to the added power. To answer your question though an intake would probably add more power with stock heads v. heads with a stock intake.
post #18 of 20 Old 07-19-2009, 04:38 PM
SKYWLKR's Avatar
Use 8548 pt2's, they will hold almost anything unless your tune is off.
Get a BTM I always liked the ability to dial some timing out if the weather was REALLY hot or I got bad gas or something.
89 LX 5.0: 342 Performer 5.0's, GT-40 [email protected] & [email protected] on 100 shot
Monster Miata: 5.0 stock motor,times soon
LSB e46 M3 Vert: [email protected]
SKYWLKR is offline
post #19 of 20 Old 07-19-2009, 06:04 PM
Thunder5.0's Avatar
You can also lock the timing until you get it tuned.
Thunder5.0 is offline
post #20 of 20 Old 07-20-2009, 12:36 AM
I bet it was TM.com...
Blown head gasket or intake gasket? kwikstang 5.0/5.8 Engine Tech 8 11-08-2008 11:21 AM
Bought used heads:Possible Bad head or blown head gasket? Pics inside EvinH 5.0/5.8 Engine Tech 3 04-10-2008 06:19 PM
anyone here ever blown a waterpump gasket and thought it was a head gasket? Mize blown89lx Superchargers 6 07-14-2006 09:14 PM
Blown Head Gasket vs Bad Intake Gasket? How to diagnose? Coolant in Oil!!! FastGT94 5.0/5.8 Engine Tech 6 04-25-2006 10:12 AM
