How Much Power - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 07-13-2009, 10:27 PM Thread Starter
mike06tr's Avatar
How Much Power
Is a MP70mm Turbo good for?
I am thinking about putting a turbo kit on the engine
in my sig. Want it to spool quick and make around 600whp.
Thanks, Mike
Cheaper than VHT and works great.
So sticky it will practically pull your shoes off, just like the movie theater
floor..
mike06tr is offline
post #2 of 15 Old 07-13-2009, 10:53 PM
I personally would not run one on a 347 just because of the sizing. I am sure it will work and probably spool up rather quickly but kind of undersized for the cubes and flow of the motor regardless of the power goals.
post #3 of 15 Old 07-14-2009, 01:20 AM
slo5.0.'s Avatar
i run one.. it is a little small but makes over 6 no issue and full spool at 3700 .96 a/r and a 360 ci motor
slo5.0. is offline
post #4 of 15 Old 07-14-2009, 07:25 AM
Steve O.'s Avatar
As mentioned above it maybe on the smaller size when looking for the optimal turbo. What a/r is it? It would be great for the street and have great power, practically off idle. If you already have it and are new to turbos keep it. If you are shopping for one then there maybe one that is better suited for your application. To answer your other question, several board members have gone mid to high 10s with that turbo and a lot less motor than yours.
Good Luck!
Steve
Steve O. is offline
post #5 of 15 Old 07-14-2009, 09:24 AM
I do not think the power capabilities are an issue but the sizing of the turbo for the flow of the motor is off. You definitely would want the bigger housing as the other member mentioned they have, if you are have the turbo already and will be running it. Don't they make a 76 turbo, I'd go with that for that size motor.
post #6 of 15 Old 07-14-2009, 09:50 PM Thread Starter
mike06tr's Avatar
OK I will look at the 76mm.
floor..
mike06tr is offline
post #7 of 15 Old 07-15-2009, 09:57 PM Thread Starter
mike06tr's Avatar
They don't make a 76mm. I would get the one with the larger housing.
floor..
mike06tr is offline
post #8 of 15 Old 07-15-2009, 10:24 PM
salley347's Avatar
Do a little more research, I'm pretty sure they've released the 76mm with a .96 ar!
92 Lx hatch, 331
90 7-Up
salley347 is offline
post #9 of 15 Old 07-16-2009, 12:26 AM
8950LX's Avatar
Trader Feedback: (47)
You are correct. They also will have a T88 available as well.
92 Titanium Frost LX
8950LX is offline
post #10 of 15 Old 07-16-2009, 01:15 AM
salley347's Avatar
Is it a t6 flange?
92 Lx hatch, 331
90 7-Up
post #11 of 15 Old 07-16-2009, 05:38 AM Thread Starter
mike06tr's Avatar
I will look at thier sight again..
floor..
mike06tr is offline
post #12 of 15 Old 07-16-2009, 10:13 AM
Who told you that? Google says otherwise with the simplest search
http://www.google.com/search?sourcei...%20T76%20turbo
Looks like it was released around September of last year no less.
post #13 of 15 Old 07-16-2009, 02:41 PM
I have a MP76mm in my basement for my current build. They have them available in several housing AR's and wheel trims. PM me if you want some more details. What ever you do, don't run a 70mm if you are starting from scratch. Yes they work, but are not properly sized for your application. Enjoy!
kruser02 is offline
post #14 of 15 Old 07-16-2009, 06:35 PM
Authorized corral.net Commerical Poster - Exp 4/2010
RealStreetPerformance's Avatar
I have a bunch of logs of turbos from 70mm to 76GTS on engines from 302-347 and they all spool 10psi by 3800-4200. I would lean towards the 76mm as it's just a better match for your engine. If your willing to buy used I would keep an eye on supraforums.com I am sure some nice units will be going on the market as deeper pockets step into the billet line from Precision.
Jay M
Sales, Installations, Dyno, Fabrication, Engine Builds
850 N US HWY 17-92
Longwood, FL 32750
RealStreetPerformance is offline
post #15 of 15 Old 07-20-2009, 12:56 PM
Come to think of it... I have a Precision GT42 76mm I would like to sell. It's got a coated turbine housing and less than 2k miles on it. I had it on a car before we moved up to a 80mm. I will take $750 to your door for it.
Jay Meagher
850 N US HWY 17-92
Longwood, FL 32750
soft brakes,stiff power steering and low power...any connection? jackscagnaty 5.0/5.8 Engine Tech 6 04-03-2009 12:00 PM
No Power. Lights do not turn on. Can;t start. Power at fuse block essasin 94/95 Tech 3 01-31-2009 09:50 PM
Questions - Swapping 1996 GTS to Power Windows / Power Door Locks seriousmustangnut General Mustang Tech 6 08-31-2005 10:31 AM
SALE***90 MAF/AFM POWER PIPE/ POWER STACK AIR FILTER*** Black Stallion4 Power Adders 0 11-15-2004 10:44 PM
which power adder has the most power potential? vortech x trim or pt88 ? quicktime Turbochargers 27 10-31-2004 09:01 AM
