Need help asap!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 07-12-2009, 11:13 PM Thread Starter
Djstorm100's Avatar
Need help asap!!
I have a 91 lx fox...I'm more than likely going to be getting a c4 and doing a butt load of work to my stang in the next 4 days (got to get on the dyno thrusday in the am).
I've been looking at trans coolers bc I know I'll need one. I cant just mount it in the fender well bc of the IC pipes.
My set up is 306, 70mm turbo, heads, cam, intake manifold, compression drop to 8.5:1.
with a 4 inch intercooler and 3 inch radiator (fluidyne) and trans cooler I'm worried that the setup will overheat. I have a mark V8 fan and many people know it pushes ALOT of air. I'm going with the B&M supercool http://www.summitracing.com/parts/BMM-70266/
The core is 8 inches high and 11 inches wide, its a plate type so it better cools vs a tube and fins and has 36 cooling rows. If I can fit the next step up (height 9inch width is 11 with 48 cooling rows)
The only opition it seems like is to mount the cooler in the upper left or right on the radiator, but it wont get air flow it seems like bc of the bumper.
any advice?
Djstorm100 is offline
post #2 of 3 Old 07-13-2009, 11:27 AM
hotordder_101's Avatar
You could use one of these.
http://www.summitracing.com/parts/PRM-1005/?image=large
Or even something like this.
http://www.summitracing.com/parts/MOR-41200/
Luke
'94 F350 Crewcab dually 7.3 Turbo (Not Powerstroke) Deisel CLEAN
'89 Ranger 2.3 5spd Work Truck
hotordder_101 is offline
post #3 of 3 Old 07-13-2009, 12:58 PM
When I had my C6 car I mounted the trans cooler below the car, below the transmission actually and worked out very well. My friend's C6 car he mounted it below one of the front frame rails and had an electric fan off a motorcycle mounted on it.
WTB 6 bolt 4.6 fylwheel asap & 8 blot flywheel 4.6 ASAP 99v6red Drivetrain Parts 0 05-11-2009 09:38 PM
PLS. HELP ASAP B&M SUPERCHARGER FORCE INDUCTIONS!! HELP ASAP 1QUICKMAN Superchargers 1 11-02-2007 02:10 PM
Need Help ASAP Shifter/Tranny Related...chime in asap please y0rascal GT & SOHC 3 06-02-2007 08:36 PM
Need Help ASAP! Converting old Mass Air meter to Newer 90mm! Again ASAP! Whitestang5oh 5.0/5.8 Engine Tech 4 01-15-2006 11:18 AM
NEED TO BUY ASAP PARTS FOR A 96+ COBRA WILL BUY ASAP "TODAY" STANGSTROKED Modular Engine Parts 4 03-29-2005 06:45 PM
