need help bad! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 07-10-2009, 02:13 PM Thread Starter
need help bad!
ok so i replaced the head gaskets and got everything back together and now i have more blow-by than before and what sounds like a slight backfiring noise when just sitting at idle it only backfires i say like every min or so of idle and when i give it a little throttle and let off it does it too it just sounds like a kid with a cough just does it randomly its turbo charged too by the way any advise would be great
joedaddy4 is offline
post #2 of 8 Old 07-10-2009, 02:37 PM
Did you check the heads?
Stampede4ever is offline
post #3 of 8 Old 07-10-2009, 05:02 PM Thread Starter
I did and they are true
post #4 of 8 Old 07-10-2009, 05:11 PM
so is it puffing a lot out the breather or what?
how do you know the heads are flat?
streetfalcon is offline
post #5 of 8 Old 07-10-2009, 06:05 PM Thread Starter
yes its coming out of the breather and i work in a place that has calibrated tools and just so happen we have calibrated straight edges to use
post #6 of 8 Old 07-11-2009, 11:29 AM
red89coupe's Avatar
Trader Feedback: (31)
improper valve adjustment or possibly a tooth off on the distrib ??
give her a doubble check on IF everything is hooked upand IF its where it should be.. usually its something STUPID.
red89coupe is offline
post #7 of 8 Old 07-27-2009, 04:46 PM Thread Starter
yup it was a stupid fix it was caused by two stripped bolts secring the upper intake to lower intake causing air to excape thanx for all the input
post #8 of 8 Old 07-28-2009, 06:02 PM
Why did this cause exessive blowby?
87TurboGT is offline
2000 4.6L v8 PI motor with bad cams bad rod bearings $400 californiabratt Modular Engine Parts 1 03-02-2009 11:26 PM
Where does the coolant passage in back of drivers head go? Bad bad luck... Mustang Matt SVT & DOHC 1 06-24-2007 08:58 PM
STAGE 3 FOX LAKE VIC JRS BAD BAD BAD BOYS BRIAN CRAWFORD RACIN Windsor Engine Parts 11 11-18-2005 07:04 PM
How bad will bad 02 sensors and a bad vucum line effect a dyno tune flip180 GT & SOHC 5 06-23-2003 01:32 PM
Would a cat with the material loose and bad EGR valve make gas mileage bad? cecguy 5.0/5.8 Engine Tech 1 03-20-2002 01:25 PM
