What Header Gaskets Do I Use??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 07-09-2009, 09:40 PM Thread Starter
Trader Feedback: (-1)
i got a ponydown hotside kit going on my 351w what is the best header gasket to use? I have read that most people are just using a rtv silicone is this true? If so what kind do i want and how much do i apply?
0402vette is offline
post #2 of 16 Old 07-09-2009, 10:25 PM
jturmanator's Avatar
Rtv silicone, It's gold or red looking. Just enough so it starts sqeezing out when you torque the header bolts.
jturmanator is offline
post #3 of 16 Old 07-09-2009, 10:30 PM
biminiLX's Avatar
RTV hi-temp copper
I put a fat bead down and let it get tacky/slightly pruned looking and then install.
I may have used too much last time I wrapped my headers but it didn't leak and cleans up easy.
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #4 of 16 Old 07-09-2009, 11:18 PM
copper silicone, never had it leak and have done multiple turbo cars
fourvalvegt is offline
post #5 of 16 Old 07-10-2009, 07:54 AM
PoonRacing's Avatar
Red hi-temp RTV on mine.
1995 Sapphire Blue GT - 1 owner
302, single 76mm
PoonRacing is offline
post #6 of 16 Old 07-10-2009, 08:42 AM
ratedz's Avatar
Hi temp copper RTV on mine
1986 Mustang GT
525hp/626tq
ratedz is offline
post #7 of 16 Old 07-10-2009, 12:33 PM
I don't mean to be a dick, but if this was a sticky would anyone read it? I'm not on this site much, mainly turbo mustangs but geez. This question comes up at least once a week. Someone should do a write up with pics.
87TurboGT is offline
post #8 of 16 Old 07-11-2009, 09:52 PM
rtv for me
L&StangNC is offline
post #9 of 16 Old 07-13-2009, 12:40 AM
takdashark's Avatar
I used a regular gasket and it's leaking now!! I'm going with the copper rtv recommended by a good friend who has built a few trubo cars last year. He said he's never had a problem with it...
86 Coupe, 524rwhp 597rwtq, MMR 900 5.4, DSS 2v cnc ported heads with Precision 76mm, , tremec 3550, 3.27's, TEAM Z, Maximum Motorsports, Bilstein
takdashark is offline
post #10 of 16 Old 07-13-2009, 11:39 AM
Has anyone ever tried a carbon gasket (or one with carbon inserts)? This was recommended to me, and I'm going to give it a shot.
I found these on Summit... http://www.summitracing.com/parts/PH...4/?image=large
SonicFox is offline
post #11 of 16 Old 07-13-2009, 11:52 AM Thread Starter
let me know how they work out. If not good i will just use the rtv like everybody else is doing and saying works fine.
post #12 of 16 Old 07-13-2009, 05:23 PM
Shanenindy's Avatar
Hold up... Are you guys just running straight rtv? no gasket all?
Shanenindy is offline
post #13 of 16 Old 07-13-2009, 07:04 PM
remflex gaskets have got some really good feedback on turbo setups. If you aren't confident that your headers are perfectly flat, then get a remflex. They can only be used once, though.
Zeet's5.0 is offline
post #14 of 16 Old 07-13-2009, 10:38 PM
357poweredstang's Avatar
Yessir, no gasket, only thing in between the head and header is the rtv.....I'll be doing the same, seems to be the best idea unless you have some warped header flanges or something then I would try remflex or some kind of deadsoft aluminum gaskets
87 GT 306 machined/built by me..Windsor Jr heads, E cam, GT40, lt's, Tremec 3550 etc....Tweecer R/T tuned PLX wideband
Bunch of parts for sale..306, fully forged 347, 0 mile 357, Fully Forged 408, tremec trans, clutch, and more....
357poweredstang is offline
post #15 of 16 Old 07-13-2009, 11:53 PM
Will Evers's Avatar
If your flanges are warped, take the headers to a machine shop and have them trued....
Then, use some copper silicone!
Will Evers is offline
post #16 of 16 Old 07-15-2009, 10:21 AM
killacal's Avatar
I'm running felpro composite gaskets w/ ARP header studs.... get some studs, they're cheap and work great.
'89 Notch TT w/ custom tunes by Cal
killacal is offline
Quick header/header gasket question (I have diffrent heads which gaskets?) help! Matt5.0 94/95 Tech 2 04-30-2005 11:13 PM
Best header gaskets and header bolts? 5150 General Mustang Tech 19 01-10-2004 06:24 PM
header gaskets blue2000gt GT & SOHC 1 08-26-2003 10:51 AM
Help with Header gaskets! Rice Hunter SVT & DOHC 3 07-26-2003 02:35 AM
Header gaskets etc... PHANTA-Z 5.0/5.8 Engine Tech 2 10-09-2002 03:19 PM
