For those thinking of getting an on3performance turbo kit Dyno Results!!!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 31 Old 07-09-2009, 07:55 PM Thread Starter
1993 Mustang LX
Stock Heads and Cam
Professional Products Intake Manifold
Brian Turner
4 Mustangs and a Z06
Mobile Chassis Dyno is offline
post #2 of 31 Old 07-09-2009, 09:42 PM
more info of your combo please, nice numbers btw.
Turbomustang
Mesarina is offline
post #3 of 31 Old 07-09-2009, 10:21 PM
jturmanator's Avatar
tick, tick, boom!
jturmanator is offline
post #4 of 31 Old 07-09-2009, 10:25 PM
ratedz's Avatar
More on the combo
What turbo size? How much boost? How much timing?
1986 Mustang GT
525hp/626tq
ratedz is offline
post #5 of 31 Old 07-09-2009, 10:52 PM Thread Starter
Originally Posted by jturmanator View Post
tick, tick, boom!
MLS Head Gaskets and ARP Head Studs
20 degrees of timing on low boost.
17-18 degrees of timing on high boost.
There are a number of 500 rwhp S trim cars running around on stock short blocks. I imagine this one will live for awhile.
MPT70 is on this kit.
Brian Turner
post #6 of 31 Old 07-09-2009, 10:58 PM
Maybe I will turn mine up one day! Looks like he is pushig upwards of 15lbs on high boost. I did the ARPS studs also, except I went with Fel 9333's.
I'm running 18* deg on 93 octane and 20* on 110
My tuner told me I should see 500 HP at 14lbs. Just not ready to push it just yet, good numbers by the way.
post #7 of 31 Old 07-09-2009, 11:04 PM Thread Starter
I am sure you will just fine. Just keep the fuel to it and keep it under 6000 rpms. I am still waiting for my incon car to pop.
See my sig below.
Brian Turner
post #8 of 31 Old 07-09-2009, 11:20 PM
I don't really think people's concerns with the kit is the power capabilities at all. Every turbo kit out there seems to be able to make great power. \
The concern I personally have with it (and I'm sure others as well) is the longevity of it and whether or not they keep the sway bar since some say they don't keep it and then the new one says it does keep it.
I'm not going to lie, the price of it is extremely enticing to me. and since my car is 95% street car 5% track time, but I'm not interested in buying something for my car that I have to hack the crap out of it just to make it fit because its not some race car that I don't care about what I hack up or whatever I have to do to make it go fast.
That's my 2 cents on it. Great numbers tho
Nick.
(PS If you can answer any of these questions for me in a PM or reply on here that would be nice)
Carb swap in progress...
Scout2232 is offline
post #9 of 31 Old 07-10-2009, 12:38 AM
Hey Scout I have been watching o3p over on the turbo forums and there was a post over there somewhere that said his headers and i think the crossover were made out of mild steel now and that he moved the crossover around a inch to make sure you can keep your sway bar. But if you want a great kit at a good price that you know is gonna work you should look into B&G Custom if you havent already, I have heard nothing but great stuff about them and from the couple times I have talked to Brian he is a great guy to deal with. The problem I have with o3p is everytime I have seen someone do a build thread over there he is in the thread and watching it BUT when something goes wrong hes no where to be found and wont respond to that persons e-mails either.
manics93 is offline
post #10 of 31 Old 07-10-2009, 06:15 AM
millhouse's Avatar
Good numbers as expected with most turbo kits. It looks like the wastegate is a bit small, as you are getting 2psi of creep.
I take it that was with race fuel? I'd venture to say with a standard tune (less timing)on 93 octane, you're typical daily driver is going to lose a good 20-30rwhp.
As for it living a while...it very well could do so, especially if it's a weekend warrior only. That's a ##### ton of boost to run on anything but a weekend warrior though.
What were the sae correction factors at anyways?
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #11 of 31 Old 07-10-2009, 09:58 AM
As far as the sway bar, I remember that being a complaint about the original PTK kits and someone saying this is a copy of those kits. For some reason I seem to recall the sway bar could work with a PTK kit but you had to go to SN95 end links or some crap along those lines. I do find it funny people actually worry about that detail on a cheaply priced kit but back when the PTK kits were out no one seemed to care yet they were paying a ton more.
I ran 18lbs of boost out of an S-trim in my old street car and for 1-2 years without a single issue from the boost. I finally got rid of it because the seals in the S-trim kept blowing out. That was a setup using pump gas almost exclusively and no after/intercooler and actually no tuning aids(piggy back or custom chip).
post #12 of 31 Old 07-10-2009, 10:11 AM Thread Starter
Mill house.
I will have to go to the dyno and and see what the correction factor was. I believe it was 1.01%.
This was on pump gas using 94 octane sunoco. The boost is back down to running off the waste gate. Looking back at the logs. timing bounces between 19-20 degrees. I ran the stock A9L timing curve on my incon car for 20,000 miles at 10-11 psi with aluminum heads without any problems.
This car is owned by a friend of mine from Florida who came up to Ohio get it tuned. It has the mild steel kit installed. Hopefully everything holds up for a long time.
Brian Turner
post #13 of 31 Old 07-10-2009, 10:29 AM
millhouse's Avatar
Originally Posted by Mobile Chassis Dyno View Post
Mill house.
So you’re running 20* total on nearly 12lbs of boost? Likewise with the 18* total with nearly 16!?! Running 26* total with aluminum heads is a walk in the park with 10-11 psi (I run 24* total with 8…but I’m playing it safe). Running 20* total with 12lbs on the stock iron heads without race fuel or meth injection IMHO is crossing the line. You’re basically retarding the ignition .5 degrees for every psi he’s running. If not for those MLS gaskets, I’d bet your friend would be popping a standard gasket REAAAAL soon. I see a new block and rotating assembly in his near future.
Did you tune the high load, low rpm areas with such aggressive timing too? What happens when he runs that tune in the hot & humid Florida heat with some 93 octane? Not to sound disrespectful....but that sounds as far from a safe tune as you can get. Sure it dyno’s well…but at what cost?
post #14 of 31 Old 07-10-2009, 10:46 AM Thread Starter
Not disrespectful at all. We talked about the florida heat and that some race gas should be added if he is going to be racing the car in the florida heat. I also have timing pulled back if the IAT's start to get out of control. No signs of detonation on the plugs. At least I could not see any black spots of melted aluminum. I think he will be just fine. A/F is in the low 11's
Brian Turner
post #15 of 31 Old 07-10-2009, 10:49 AM
millhouse's Avatar
He'll be in my prayers.
post #16 of 31 Old 07-10-2009, 10:53 AM Thread Starter
Brian Turner
post #17 of 31 Old 07-10-2009, 11:17 AM
ratedz's Avatar
I take it my timing is too low at 17* on 12lbs?
1986 Mustang GT
525hp/626tq
ratedz is offline
post #18 of 31 Old 07-10-2009, 11:21 AM Thread Starter
Your timing is fine.
Brian Turner
post #19 of 31 Old 07-21-2009, 12:14 PM
91foxbody's Avatar
Car runs amazing Brian, thanks again!!!
91foxbody is offline
post #20 of 31 Old 07-21-2009, 04:55 PM
Trader Feedback: (178)
Dont you have a 99 GT to run......
Speeds8erM-1 is offline
post #21 of 31 Old 07-21-2009, 10:21 PM
AMiran02GT's Avatar
awwww shiiiiiit!
Adam
2002 GT - never ending turbo build
AMiran02GT is offline
post #22 of 31 Old 07-22-2009, 08:39 AM
91foxbody's Avatar
How am I supposed to run something that doesnt have a transmission in it??
post #23 of 31 Old 07-22-2009, 11:10 PM
92stanggt5.0's Avatar
I don't understand why my car doesn't make that much HP. I make a little more torque at 13lbs but my HP is no where near that. I'm confused.
1995 Cobra white/tan and a T64
92stanggt5.0 is offline
post #24 of 31 Old 07-23-2009, 05:58 AM
Rich G's Avatar
Trader Feedback: (35)
I dont understand why my turbo car makes more hp than torque lol
Rich G is offline
post #25 of 31 Old 07-23-2009, 01:39 PM
He already got one for it
post #26 of 31 Old 07-23-2009, 05:23 PM
I'm guessing its cause its a stock head cam car, and you would make more tq than hp with out the turbo. Thats awsome!
Stock mustang+1400dollar turbo kit= 10 sec mustang. Thats gotta piss alot of people off.
JBIGBOOTSY is offline
post #27 of 31 Old 07-23-2009, 09:55 PM
ben5.0's Avatar
Trader Feedback: (38)
I would like to know how the mild steel headers hold up!
ben5.0 is offline
post #28 of 31 Old 07-24-2009, 01:26 AM
Cartech's been doin it for years. Along with other companies of course. Mild steel = fine by me.
post #29 of 31 Old 07-24-2009, 07:59 AM
Cartech switched back to mild steel so they could be more competitive with their pricing. What I find funny about that is they switched from mild steel to 304 stainless well over a decade ago because the mild steel was crack city on their fox body street kit.
post #30 of 31 Old 07-24-2009, 08:08 AM
90Notch302's Avatar
x2
Tremec 3550, Spec stage 2,Alm. Driveshaft, SteedaTri-Ax, 3.73's,65mmTB, adjustable FPR, BBK long tubes, BBK h-pipe w/o cats, Edelbrock exhaust,e-fan, 50/50 and 70/30 lakewoods, LCA's, Eibach drag launch,GT40upper/lower, GT40 heads, 1.7 RR's, 75mm Mass-Air, 24lb's.263hp 306ft/lb
90Notch302 is offline
post #31 of 31 Old 07-24-2009, 06:16 PM
Don't say that! I don't want mine to crack! J/K
Got My ON3performance 2v KIT 2002mustanggt Turbochargers 1668 08-04-2017 12:30 PM
on3performance turbo kit 2002mustanggt Turbochargers 85 01-16-2009 12:11 AM
crappy dyno results "GOOD TRACK #'S" quicktime turbo kit cesna150 Turbochargers 22 05-17-2008 03:37 AM
crappy dyno results "GOOD TRACK #'S" quicktime turbo kit. cesna150 Drag Racing 5 05-11-2008 07:59 PM
Turbo dyno results slowstang101 94/95 Tech 27 09-28-2007 03:06 PM
