Quick question about my Quicktime turbo drain..PICS..QTK owners come in! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 07-08-2009, 01:26 AM Thread Starter
357poweredstang's Avatar
Arrow Quick question about my Quicktime turbo drain..PICS..QTK owners come in!
Finally getting around to getting my Quicktime turbo kit together and just want to make sure on something....The 2 bolt flange gets bolted to the bottom of the turbo, then the blue fitting on the left is screwed into that, which is connected to the braided line, the end of the line connects to the blue fitting on the right then that screws to the gold fitting on the very right, which is then threaded into the pan...correct?
And anybody where these bolts go....
Assuming the 4 thats together hold the turbo to the flange...
2 of the 6 with the lock washers bolt the aluminum flange to the bottom of the turbo and the 4 of the 6 hold the intercooler brackets to the intercooler? and the 2 self tapping screws secure 2 of the intercooler brackets to the car chassis?
87 GT 306 machined/built by me..Windsor Jr heads, E cam, GT40, lt's, Tremec 3550 etc....Tweecer R/T tuned PLX wideband
Bunch of parts for sale..306, fully forged 347, 0 mile 357, Fully Forged 408, tremec trans, clutch, and more....
357poweredstang is offline
post #2 of 8 Old 07-08-2009, 06:41 AM
mustang alley's Avatar
That all sounds right to me. You must have been one of the lucky ones if you received all that hardware with your kit, I wasn't as fortunate!!
89 Mustang LX 5.0
Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoatnt tihng is taht the frist and lsat ltteer be in the rghit pclae.
mustang alley is offline
post #3 of 8 Old 07-08-2009, 08:38 AM
ratedz's Avatar
Correct - and the 4 on the far right are for mounting the turbo IIRC
I was also fortunate in receiving all of my hardware. One thing to check tho - make sure the weld on the turbo header where the crossover tube connects is a good weld. Mine pulled apart last night on me - not a crack, it just looks like that weld wasn't melded very well. I'll post pics later when I take it apart.
1986 Mustang GT
525hp/626tq
ratedz is offline
post #4 of 8 Old 07-08-2009, 07:01 PM Thread Starter
Yeahh, well lucky for me I bought it off a friend and he had bought it from the original buyer that got it from QTK, like a year or longer ago when they were doing good and replying to people still.
Can't wait to get this thing on and tuned...
Should I use any sealer or teflon tape on any threads? I would assume no since they have a that machined fit on the inside and some have tapered threads but just checking......
Also was thinking about getting a bead of weld around that fitting when I get it in the pan to make sure it's tight and won't leak.
post #5 of 8 Old 07-10-2009, 11:33 PM
jturmanator's Avatar
I used teflon tape on the AN fittings, also used rtv gold silicone on that alum piece that bolts to turbo drain and on the fitting that threads into oil pan.
No leaks.
jturmanator is offline
post #6 of 8 Old 07-10-2009, 11:38 PM
Trader Feedback: (38)
teflon past on all the NPT threads, light coat of oil on the AN fittings.
definitely have the oil drain fitting welded to the pan.
rforres is offline
post #7 of 8 Old 07-11-2009, 06:55 PM Thread Starter
Now thinkin about just putting in a hole for the fitting then getting it welded instead of the punch and tap deal although it couldnt hurt so it could hold the fitting tight while its getting welded
How about the flange that bolts to the bottom of the turbo, I don't have a gasket for it, should I use one or just use sealer?
post #8 of 8 Old 07-11-2009, 07:10 PM
Ultra copper RTV
rforres is offline
First turbo (quicktime) install...**pics** notch88 Turbochargers 35 02-21-2009 12:24 AM
QuickTime Turbo Systems kit arrived today - pics and review inside ratedz Turbochargers 23 01-08-2008 02:19 AM
Quick Question for C-4 owners!! Nutzz General Mustang Tech 4 10-02-2007 11:00 AM
Quick question to all the new owners Eagle11401 S-197 Mustang (2005-2010) 1 10-28-2004 01:57 PM
VORTECH Owners...Drain Hose Question! 94GTLaserRC 94/95 Tech 12 08-05-2004 08:31 PM
