Building 357w, parts question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 07-07-2009, 10:32 PM Thread Starter
jfitts23's Avatar
Arrow Building 357w, parts question
well my plan is end up with a 357 with a mp t76 turbo wanting 600 or 700 rwhp. Question is i want to grab a block out the junkyard, can i use the stock crank,rods, and just put some fordged piston in there and be fine. Or should i do fordged rods and pistons. If so what size pistons and rods should i get. part numbers would be appreciated or links. i have some AFR 58cc 205 heads trying to get down to 8.5:1 compression. Thanks for the help
jfitts23 is offline
post #2 of 8 Old 07-07-2009, 10:53 PM
1BAD6T6's Avatar
My goals are similar to yours. I'm running the following:
94 F4TE 351w roller block
Stock cast crank
Eagle SIR forged rods 5.956"
TRW 2446F30 Forged pistons 13.2cc dish
With a stock block the pistons are .025" in the hole giving me 9.48:1 compression with a .047" head gasket and 58cc heads. I'm shooting for ~9:1 CR which is a 62cc head.
1966 Mustang Coupe
1993 Coupe - LM7, pt88, th400, MS3x
1995 GT - 100% Stock (emissions and all)
1BAD6T6 is offline
post #3 of 8 Old 07-07-2009, 11:02 PM Thread Starter
jfitts23's Avatar
so would this work these pistons say they would give me 9.0 compression with 58cc heads. http://www.summitracing.com/parts/SRP-138722/ i would get some 64cc heads but my friend gave me such a good deal on new afr 205 heads i can't pass them up. and would these rods work http://www.summitracing.com/parts/ESP-5956FB/ so if i get these to i should be good to go with stock everything else?
jfitts23 is offline
post #4 of 8 Old 07-07-2009, 11:02 PM Thread Starter
jfitts23's Avatar
i got a 93 lx vert too. trying to do the same thing wierd.lol
1987 GT Convertible
2013 Shelby GT500
jfitts23 is offline
post #5 of 8 Old 07-07-2009, 11:30 PM
1BAD6T6's Avatar
I know, weird. Those pistons, according to my calc, would give you 8.58:1 w/ a .047" gasket. I have those rods. Should work great.
1966 Mustang Coupe
1BAD6T6 is offline
post #6 of 8 Old 07-07-2009, 11:36 PM Thread Starter
jfitts23's Avatar
Ok great thats right were i want to be. Thanks for the help.
1987 GT Convertible
2013 Shelby GT500
jfitts23 is offline
post #7 of 8 Old 07-12-2009, 10:49 PM
97SVT's Avatar
'84 block, stock crank, Sir Eagle rods 5.95, TRW pistons .040 L2378F40
Holding up so far w/ times in sig
1967 Mustang Coupe
1990 Mustang GT Turbod DD
1987 Mustang GT Turbod-9.75 @ 140mph gone but not forgotten
97SVT is offline
post #8 of 8 Old 07-12-2009, 11:06 PM Thread Starter
jfitts23's Avatar
whats your compression and what heads do you use.and hp?
1987 GT Convertible
2013 Shelby GT500
jfitts23 is offline
357w Rotating Assembly 1974 Windsor block..351w Parts.. ALL NEVER RAN!!!! 357poweredstang Windsor Engine Parts 2 04-15-2009 08:47 AM
Complete Ford 357w 0 Miles On Everything! TRW forged pistons, 302/351 Parts, + More 357poweredstang Windsor Engine Parts 1 04-07-2009 12:31 PM
Help with building a n/a 97...parts selection... 97QUICKSNAKE SVT & DOHC 0 07-19-2008 02:51 PM
NEW '69 357W and some other parts 351vic Windsor Engine Parts 4 04-16-2008 08:04 PM
building budget hp. how much hp from these parts? calypsofourbeat93 5.0/5.8 Engine Tech 4 08-02-2006 05:55 PM
