Flywheel choice steel or aluminum? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 07-05-2009, 12:05 AM Thread Starter
Which is better setup for a street driven car a billet steel or aluminum flywheel? I currently have an aluminum setup with a Mcleod twin disc, but I was wondering if I'm leaving a bunch on the table in regards to spool up time.
got9lbs is offline
post #2 of 6 Old 07-05-2009, 12:36 AM
CaliNotch n MI's Avatar
Trader Feedback: (15)
I'm running an aluminum, I like it but I think it kills me at the track....
1993 Notch: Mexican 347 Hellion TFS heads/GT40 intake/Custom Cam Tremec 3550
1992 GT Convert: Green/Blk interior, 10th anniversary cobra's mostly suspension mods.
FB users please, PLEASE click "like" button. Thanks!!
CaliNotch n MI is offline
post #3 of 6 Old 07-06-2009, 06:05 AM
357poweredstang's Avatar
I've always used steel, aluminum is less weight, but doesn't have the momentum/rotating mass like a steel one does that can be helpful when you get into the next gear or I would think would also help load the turbo some too.
87 GT 306 machined/built by me..Windsor Jr heads, E cam, GT40, lt's, Tremec 3550 etc....Tweecer R/T tuned PLX wideband
Bunch of parts for sale..306, fully forged 347, 0 mile 357, Fully Forged 408, tremec trans, clutch, and more....
357poweredstang is offline
post #4 of 6 Old 07-15-2009, 07:26 AM
Yeah I heard steel is better for the track
"ITS LIKE A FINGER POINTING AWAY TO THE MOON"
99 Mustang Saleen
4.6 DOHC Hellion twin 61mm turbos intercooled
684 RWHP/ 645 TQ @ 13psi
Supergt98 is offline
post #5 of 6 Old 07-16-2009, 09:46 AM
Authorized corral.net Commerical Poster - Exp 4/2010
RealStreetPerformance's Avatar
There is nothing wrong with light rociprocating parts. The less inertia the rociprocating assembly has the less likely it is to break tranny parts... If you had an engine that made very little torque a heavy flywheel can help. Think about that rotary that you see at the the dragstrip.They leave on a flywheel and are out of power by the 330', but still et well. I don't even think the guys in Pure Street are using heavy flywheels and they make peak torque around 6k...
Sales, Installations, Dyno, Fabrication, Engine Builds
850 N US HWY 17-92
Longwood, FL 32750
RealStreetPerformance is offline
post #6 of 6 Old 07-16-2009, 09:51 PM
sounds good cause I was thinking of changing mine to billet steel wasnt looking forward on pulling the tranny ill keep my aluminum
99 Mustang Saleen
Aluminum vs. Steel flywheel fstrthnu373 Drag Racing 0 11-19-2007 07:56 AM
Aluminum Flywheel or Steel Flywheel? You Decide fatal_attraction 5.0/5.8 Engine Tech 48 10-31-2007 04:43 PM
Which flywheel, steel or aluminum 1990LXDropTop General Mustang Tech 6 08-28-2005 05:28 PM
Aluminum vs steel flywheel Insley95 General Mustang Tech 8 01-02-2004 12:17 PM
Aluminum of Steel Flywheel Matt W 5.0/5.8 Engine Tech 0 02-08-2003 05:28 PM
