Best gear for a 5spd 96 Cobra vert? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 07-03-2009, 07:57 PM Thread Starter
goat-ee's Avatar
I searched and see alot of advise for a 3:27 on fox bodies, but very little info on my specific car (fat a**). Car made 447rwhp and then ran a 12.44 @ 115.5mph on 6-8psi my only trip to the strip with the current 4:10 gear.
So what would be ideal gear in this car as-is and also if I build a motor later and run 15-18psi. Planing on staying 5spd.
Mods in signature.
96 Cobra Vert
NEW SETUP: 60'-1.830, 11.7 @ 121.73. Hellion Single Turbo @ 10psi. UD pullies, timing adjuster, Meziere WP, Bassani Quiet Thunder w/cats, 4.10's, AL driveshaft, 315/35/17 BFG DR's.
New Driver-97 Pacific Green Cobra. Forged, 2.1 Kenne Bell, T-56, 3.73. 12.6 @ 112mph
goat-ee is offline
post #2 of 13 Old 07-03-2009, 08:12 PM
What size tire are you running?
ChaseGT is offline
post #3 of 13 Old 07-04-2009, 02:56 PM Thread Starter
goat-ee's Avatar
315/35/17 BFG Drag radial currently.
96 Cobra Vert
goat-ee is offline
post #4 of 13 Old 07-06-2009, 12:11 PM
ssj50driver's Avatar
What is the rpm you are going through the traps? What is your rpm threshold (top rpm you care to spin at)? I would say a 3.55 or 3.73 would be perfect for you since you have a 4v car. This might help with spool time in first gear. What are your 60' they will tell a lot too.
ssj50driver is offline
post #5 of 13 Old 08-02-2009, 08:07 PM Thread Starter
goat-ee's Avatar
It's a 4valve, so probably 65-6800rpm max. 60' is 1.81. Anyone have any idea how much I can hope to gain? Also is a two-step a big help at the strip?
96 Cobra Vert
goat-ee is offline
post #6 of 13 Old 08-03-2009, 07:06 PM
red89coupe's Avatar
Trader Feedback: (31)
I vote for 3.55s but Im VERY bias lol
YES a very big help IF you can hook.. Only running 6-8 psi you should be able to build FULL boost and launch off the 2 step. IF you have a way to pull timing on the 2step it will help build boost too and it can do it at lower rpm
example...mine is a stock pushrod motor but by pulling 2* on the 2 step I could build full boost (10psi) and still launch at my 3500 rpm.. I could get the 10 psi IF I set the 2step higher but then my launch rpm was "off"
I went from a 1.88 to a 1.63 60'
red89coupe is offline
post #7 of 13 Old 08-06-2009, 11:21 AM Thread Starter
goat-ee's Avatar
What is the best 2-step to buy to build boost at the line, and any other suggestions on the gear?
96 Cobra Vert
goat-ee is offline
post #8 of 13 Old 08-06-2009, 11:16 PM
red89coupe's Avatar
I used a MSD digital 6+ ign box it has a built in 2step and a timing retard. it was nice having all 3 in one box but you can get pretty much any one of them you want from MSD.
I do like 3.27's for turbo cars they work GREAT!! However I would NOT go lower then 3.55's. with that tire your looking at "only" 5300 rpm at 115 with 3.55s and 4800ish with 3.27s.. 3.73s would be more in your rpm range but I have never been a fan of higher gears with turbos.
post #9 of 13 Old 08-07-2009, 12:42 AM
5.8LiterImportEater's Avatar
I agree 100% but I think you may be attributing too much torque to the small 4v.
My buddy has 4.30's on his 98 cobra and that thing feels EXACTLY like my 5.0 with 3.73's. If I would lower my rear to 3.55's or 3.27's I wouldn't go below 3.73 with a 4v. I know that changing gears repeatedly is a bitch but the early 4v isn't even working at 5300 with your 3.55's. 5800 though for the jump to 3.73's would probably put the car in a much better power curve.
I would expect a MPH jump with the 3.73's too. Probably put you at 118 or more.
Chris
1993 Notch HCI /1994 Lightning / 1973 F250 Hiboy/ 1986 Omni GLH /
1994 Cummins 3500 / 1997 Cummins 3500 /1980 F250 6cyl
5.8LiterImportEater is offline
post #10 of 13 Old 08-07-2009, 08:22 AM
i've installed the 3.27 and i'm going twin turbo soon but i've also thought about 3.08s to take some of the steepness out of first and allow me to get more time in that gear
97 cobra
Mach1 Engine Swap,4.56s,JLT CAI,T/A cover,FoMoCo Aluminum Driveshaft,Fidanza Aluminum flywheel,bbk longtubes w/ h-pipe,hp lc arms,Fluidyne Rad,pro-5.0 shifter,Spec clutch,ford31spline traclok,moser axles,04 Chrome cobra rims,275/40 BF Gforce KD ,Smoked headlights, Mach 1 pedals,03 cobra style shifter, QA1 coilovers,SCT Tuned 311rwhp/328rwtq .......looking for the next step
97svtsnake is offline
post #11 of 13 Old 08-07-2009, 12:59 PM
Really? I just wouldn't think that a N/A car that likes 4.30's would want to drop that much.
I mean the 5.0 guys like 3.73's and then drop basically .5 to 3.27's so I figured a similar drop would be in order for the smaller motor, just from a higher starting point.
Hey guy there you go, someone with the experience, maybe 3.27's are the ticket.
Chris
post #12 of 13 Old 08-07-2009, 06:14 PM Thread Starter
goat-ee's Avatar
Is there anyone that has before and after 1/4 mile times with a change of gear being the only difference?
96 Cobra Vert
goat-ee is offline
post #13 of 13 Old 08-08-2009, 01:20 PM
yeah i went 13.1 at 106.xx with 4.10s...12.90s at 109-110mph with 4.30s and 12.70s at 111-112 with 4.56s and i never got a clean run with those gears so i left some trap speed on the table
97 cobra
89 GT 5spd Vert' AZStanger Mustangs For Sale/Wanted, 1987-1993 4 11-17-2008 08:53 PM
88 GT 5spd Vert 94MustangV6Cobra Mustangs For Sale/Wanted, 1987-1993 15 10-20-2008 05:34 PM
Looking for 94-94 GT 5spd vert jett1 Mustangs For Sale/Wanted, 1994-1998 0 07-31-2008 03:40 PM
88 5.0 5spd vert aaronlstiles Mustangs For Sale/Wanted, 1987-1993 0 04-01-2008 07:25 AM
FS 90 GT Vert, 5spd Speedfreek Mustangs For Sale/Wanted, 1987-1993 1 10-22-2004 03:55 PM
