Large Junkyard turbo with integrated waste gate? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 06-24-2009, 02:17 PM Thread Starter
SKYWLKR's Avatar
Looking for a cheap easily found Turbo that will support about 600 RWHP at 5500 max 5700 RPM on a 342 Stoker that puts out about 370 RWHP now.
VERY tight space so an integrated waste gate would be wonderful.
any ideas?
What do they flow?
something like this
http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories
http://cgi.ebay.com/ebaymotors/2001-...Q5fAccessories
89 LX 5.0: 342 Performer 5.0's, GT-40 [email protected] & [email protected] on 100 shot
Monster Miata: 5.0 stock motor,times soon
LSB e46 M3 Vert: [email protected]
SKYWLKR is offline
post #2 of 8 Old 06-24-2009, 02:59 PM
BAERSysteMAX's Avatar
Trader Feedback: (33)
those are both hy turbos with the smaller 9cm exhaust housing and t3 footprints. a single hx (larger holset found on manual trucks) will support ~500hp. for you id suggest finding a good used turbo. look into the master powers. new they are like $550 and im sure a used one could be found cheap. buy a used 38mm external wastegate, new they are $200 used for about $100. find some pipe and fitting for about $200 and an intercooler for $150 and build it yourself. you will also need some injectors, maf, blah blah.... all the supporting mods UNLESS you have them already.
90 lx 5 speed... 10.5 @ 136 stock bottom end and cam... ford junk !
86 gt ttop
90 coupe [email protected] turbo pump gas street car
BAERSysteMAX is offline
post #3 of 8 Old 06-24-2009, 03:26 PM Thread Starter
SKYWLKR's Avatar
Got the supporting stuff already.
255 Hi press pump,42lbs injectors (should be fine at 5700 RPMS), (80mm MAF for a little while) but I'll be running a mega Squirt..
SKYWLKR is offline
post #4 of 8 Old 06-24-2009, 03:29 PM
good, now scour the classifieds for some parts !
86 gt ttop
post #5 of 8 Old 06-24-2009, 03:43 PM Thread Starter
SKYWLKR's Avatar
Got any more info for turbo sizing?
I am used to turbos on the smaller motors, not familiar with the bigger singles.
Think a T4 flanged unit will support the power? or a dual port flanged t6 ?
SKYWLKR is offline
post #6 of 8 Old 06-24-2009, 05:20 PM
Trader Feedback: (41)
A T4 will support 600RWHP NP.
stangjumper is offline
post #7 of 8 Old 06-26-2009, 04:35 PM
t4 footprint. use a MINIMUM .81ar ideally a .96ar.
86 gt ttop
post #8 of 8 Old 07-02-2009, 11:22 PM
Cheap and easily found? For a 342 making 600rwhp? Wishful thinking in my opinion.
I'd probably look to find a used 76mm in the classifieds or better yet a brand new S400 and an external gate.
mustanggreg is offline
Fox Body-70mm Turbo,38mm Waste Gate w/ Intercooler svt3565 Power Adders 17 12-17-2008 06:08 PM
70mm Turbo, 38mm Waste gate w/ Intercooler svt3565 Power Adders 4 11-16-2008 12:48 PM
351w BG CUSTOM TURBO Turbo headers carb, turbo cam,pistons,gaskets,waste gate stang1986 Power Adders 8 03-25-2008 10:55 AM
F/S 94/95 Pro turbo kits Hot parts, waste gate, cut outs, and more!! Turbo308 Power Adders 5 01-23-2008 10:05 AM
New 60mm turbo, and 40mm waste gate. FS/FT vossperformance Power Adders 3 09-09-2007 10:07 AM
