Turbo xhaust? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 06-22-2009, 05:46 PM Thread Starter
Turbo xhaust?
I have an on3 kit, 3" down pipe. I cut my longtube xpipe in half and welded single 3" to that to make my ypipe. I'm running 2, 2 chamber flowmasters right now.
My question is what mufflers are the best for turbo applications. I have heard many theories, but I'm looking for some expierienced answers.
Also, if I was to just run single xhaust off the 3" down pipe, would there be any real bennifit to make a 3.5" adapter, and run the 3.5 after the downpipe?
THX.
JBIGBOOTSY is offline
post #2 of 6 Old 06-24-2009, 05:07 PM
hotordder_101's Avatar
You need straight through mufflers. Not a chambered flowmaster. The 3.5" would help but if you have 3" off the turbo to the mufflers it wouldn't be worth it. If you go from 3" to 3.5" directly out of the turbo it would be better. The reason is it will lower backpressure. Same goes for the mufflers. The less back pressure the better the turbo likes it.
Luke
'94 F350 Crewcab dually 7.3 Turbo (Not Powerstroke) Deisel CLEAN
'89 Ranger 2.3 5spd Work Truck
hotordder_101 is offline
post #3 of 6 Old 06-25-2009, 01:06 AM
jman511115's Avatar
Definitely a straight through design. Weld in an electric cutout behind the turbo too.
64,999,987 firearms owners killed no one yesterday.
NRA member and you should be too! It's about more than just the guns. Join here.
https://membership.nrahq.org/forms/signup.asp?CampaignID=FrdmAssoc
jman511115 is offline
post #4 of 6 Old 06-25-2009, 07:55 AM
not to threadjack, but I'm in the same boat, however I want my coupe to be a stealthy "sleeper" so I want it to make hp but be as quiet as a stocker if that's possible.
(h/c/i twin turbo 347 mexican block) very clean car with 17" 03 cobra knockoffs.
1 bad Mustang, 2 slow Z28's, and a Sierra crewcab for the groceries.
Racenrik is offline
post #5 of 6 Old 06-25-2009, 10:36 AM
jman511115's Avatar
You can make them pretty quiet. Mine sounds like a stocker with a catback, but when the exhaust is opened up it screams.
post #6 of 6 Old 06-25-2009, 08:09 PM
assasinator's Avatar
i use a 3"x26"x5" dynomax bullet. very quiet until the vented 60mm wastegate opens. and it sounds more like..... like a nascar stocker at 6800. i love it
it flows 2300 cfm
96 mustang GT-93 teksid 4v forged: ported heads, kellogg crank, billet i-beams, CP forged pistons, 9.4:1, BIG turbo, 4x28x12 fmic, big boost.
2011 GT 300A, 3.73, M6, spoiler delete, brembos
assasinator is offline
lots of xhaust in N.C roofer Exhaust Parts 4 02-15-2008 10:21 AM
new thought on xhaust resonance j rick kirby GT & SOHC 1 05-19-2004 08:00 AM
xhaust question j rick kirby GT & SOHC 6 12-20-2002 12:28 AM
FR500 xhaust? GRNSNK GT & SOHC 5 01-05-2002 02:37 PM
Xhaust Phreaky GT & SOHC 14 12-05-2001 10:55 PM
