tuning question with boost - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-22-2009, 12:23 PM Thread Starter
I have been monkeying with the tune in my car for the past couple of weeks. The WOT tune is dead on and some of the low loads/ part throttle tuning.
Now when I am in part throttle and hit 10psi @3500rpm (my max boost) I am seeing 14.5-14.7 is this safe? Again, at wide open throttle hitting max boost I am showing 11.5 so that is pretty much dead on.
The car doesn't ping or anything. I am probably just over thinking this.
But I am assuming 10psi is 10psi right?
Any Ideas?
- 89 Turbo coupe
-2003 10th Cobra -Gone
-1995 Mustang GT Vert-stock- Gone
forbanger is offline
post #2 of 5 Old 06-22-2009, 12:37 PM
millhouse's Avatar
Any Ideas?
Hell no it's not safe...especially considering it's likely in an area that runs far more timing than at the same boost levels during WOT.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #3 of 5 Old 06-22-2009, 12:46 PM Thread Starter
What a/f should I shoot for?
- 89 Turbo coupe
post #4 of 5 Old 06-22-2009, 01:18 PM
strokercharged95GT's Avatar
It looks like your computer is recognizing those conditions as part throttle and staying in closed loop. On tweecer I would fix the problem by changing my target AF table for the lower load and going into scalars and turing down WOT TPS breakpoint voltage to 2.1 volts and OL throttle breakpoint to around 2.5 volts. I would probably shoot for around 12.0-12.5 in those load conditions.
2013 Mercedes GLK-350
strokercharged95GT is offline
post #5 of 5 Old 06-22-2009, 07:03 PM
foxfan88's Avatar
Could also tweak the "minimum Loadx required for OL" function.
Brett
91 GT 302 CID c4 w/brake
TFS TW heads, f-cam, typhoon
70mm masterpower single turbo setup.
foxfan88 is offline
Tuning for boost solobarik MegaSquirt DIYAutotune Systems 9 01-19-2009 09:54 AM
SC 94 Vert Boost Cooler tuning UC50 Superchargers 5 08-06-2005 07:41 PM
how much more boost and a few tuning ?'s madmaxin22 Superchargers 2 01-17-2005 11:08 PM
Tuning a/f ratio under boost? Bullet306 Superchargers 8 10-18-2004 08:46 AM
PMS Tuning...Raising Boost?? SGOODRIC50 EEC Tech 0 10-22-2002 02:09 PM
