Distribution block or Junction block? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 06-22-2009, 01:21 AM Thread Starter
D O A's Avatar
Question Distribution block or Junction block?
I have many + leads (5) coming from an electric fan, water pump, msd etc. going from the front of the car to the rear battery + post. I have been told I need a distribution block or a junction block near the front of the car then one 2 gauge wire going back to the battery. I was told that the way I have the wires ran through the car now will drop voltage over a distance with the gauge wire I am using and may melt the wires or cause a fire.
Does anyone have a picture of one of these installed or what a junction block looks like or what I should use?
Thanks,
Ben SEMPER FI
88 Notch. QT PT 6776 turbo kit, Edelbrock RPM, Cometic, Crane 1.6, f303, LW bell, 6 pt., 3.73, strange adj. 6AL, MB Jr. upper/lower control arms, T5-Z, SRP pistons, main support, windage tray, FAST XFI, Strange spool & 33 spline axles, c-clip, Spec III, Flaming River man. rack, Team-Z anti-roll
D O A is offline
post #2 of 13 Old 06-22-2009, 01:49 AM
I used the stock starter solenoid post, and ran a 2/0 welding cable to the kill switch mounted behind the rear plate then to battery in the trunk. I'm running dual electric fans, an MSD-6BTM box, a 200-amp alt, and all the other stock electrical stuff.
SonicFox is offline
post #3 of 13 Old 07-06-2009, 09:56 PM
huafist's Avatar
This.
huafist is offline
post #4 of 13 Old 07-06-2009, 10:10 PM
Rich G's Avatar
Trader Feedback: (35)
http://www.racepartsolutions.com/products.asp?cat=37
Rich G is offline
post #5 of 13 Old 07-07-2009, 06:23 AM
1995gtCPE's Avatar
Trader Feedback: (34)
http://www.jegs.com/i/JEGS/555/10521/10002/-1
1995gtCPE is offline
post #6 of 13 Old 07-07-2009, 01:12 PM
TwnT70s's Avatar
Trader Feedback: (25)
great post. I have similar issue as you. Now I have some idea.
TwnT70s is offline
post #7 of 13 Old 07-08-2009, 11:30 PM
Will Evers's Avatar
Have you tried shutting your car down with that kill switch while it was running?
Will Evers is offline
post #8 of 13 Old 07-08-2009, 11:32 PM
Will Evers's Avatar
Thanks,
Ben SEMPER FI
This is what mine looked like as I was laying it out. Its a Dual Junction block with 3/8 hole eyelets on the wire.
1 of the 4ga going forward is to the starter solenoid (right in the fender). The other is the alternator cable going straight to the batt (on the un-switched side). The 2ga comes from the master on-off switch and gets split at the junction block to my switch panel and starter.
post #9 of 13 Old 07-09-2009, 12:30 AM
Yup, the first thing I did when I was done was to test it. I have the alt running back to the kill switch as well.
SonicFox is offline
post #10 of 13 Old 07-09-2009, 07:48 AM
Will Evers's Avatar
Good...a major mistake is that people leave the alternator hooked up as normal when it needs to be connected to the unswitched side.
They get f'd when they kill the battery and the alternator keeps the car running.
post #11 of 13 Old 07-09-2009, 11:07 AM
fred50stang's Avatar
Good post DOA! Thanks for the info guys. I was trying to run everything off my starter solenoid and always had a drop in voltage even with the 200amp alt.
fred50stang is offline
post #12 of 13 Old 07-09-2009, 11:57 AM
Absolutely. I made sure to research, and ask someone who knew about this stuff more than me before I even started the relocation.
Here's what my switch looks like. The green wire is 14 gauge, and runs to the alt.
SonicFox is offline
post #13 of 13 Old 07-09-2009, 12:30 PM
modo's Avatar
i had a somewhat similar issue on my car and i use a marine "bussbar"
My needs were inside the car for my gauges / wideband / computer / injector driver etc. I made a bracket that uses the center console studs as a mount. On the bracket is the bussbar, and a relay that is triggered on via the key on power to the radio harness. I used a 10 gauge feed from the starter relay post which is fused. I also ran a ground from the body mount behind the battery to the other side of the bussbar. That gave me protected postive and negative connections nice and neat under the dash.
here is a pic of it
http://www.oldecityit.com/holding/Images/bracket3.jpg
might give ya a idea
93 GT
66 Coupe
modo is offline
Distribution block for negative. ABRich General Mustang Tech 0 03-12-2009 07:29 PM
Distribution Block or What? liltroy3333 5.0/5.8 Engine Tech 3 09-14-2007 05:59 PM
brake distribution block bad seed General Mustang Tech 1 03-23-2007 09:51 AM
what does the S/C go to on the vacuum distribution block on a 91 5.0 ? red93notch General Mustang Tech 2 03-07-2006 10:51 PM
Silicon at timing cover/block junction when using 1 piece oil pan gasket?? StarrMan 5.0/5.8 Engine Tech 6 06-01-2005 01:46 PM
