how well would 60cc performer heads work on a turbo car? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 06-21-2009, 12:20 PM Thread Starter
ls1killa's Avatar
here's my set up, 331 stroker ( boss block ) i have a set of edelbrock performer 60cc 190/160 valve heads that i have laying around and a master power t61 from my old set up. my thing is this, can i get away with using these heads be fine for now or would i have to sell the heads in favor of 64cc heads? looking to run between 12-14 psi on the street daily driver.
real worriors are driven everyday not just on weekends!
ls1killa is offline
post #2 of 14 Old 06-21-2009, 12:27 PM Thread Starter
ls1killa's Avatar
forgot to add I'm ditching the nitrous and converting back to turbo again!
ls1killa is offline
post #3 of 14 Old 06-21-2009, 03:21 PM
I'm running out of the box performer heads with 1.90 valve but with a 306 and a 60mm turbo and I'm running [email protected] with 15 psi.
turbomut is offline
post #4 of 14 Old 06-22-2009, 12:14 AM
Just run it . . . I have ported e7s and I would LOVE to run something like that I just had "laying around"
streetfalcon is offline
post #5 of 14 Old 06-22-2009, 05:38 PM
Try a thicker head gasket.
JBIGBOOTSY is offline
post #6 of 14 Old 06-22-2009, 05:54 PM Thread Starter
ls1killa's Avatar
you guys are the best thank you for your replys.
ls1killa is offline
post #7 of 14 Old 06-22-2009, 05:55 PM Thread Starter
ls1killa's Avatar
Smile
what size would i need?
ls1killa is offline
post #8 of 14 Old 06-22-2009, 06:00 PM
Well, it all depends on what your compression ratio is, what you want it to be, how much boost you run, and how much you want to run.
Do you know your current static comp. ratio? Also what gasket are you currently running. And what is your bore size?
post #9 of 14 Old 06-22-2009, 06:18 PM Thread Starter
ls1killa's Avatar
Cool
i didn't realize that i had so much laying around in my garage. the problem was i started a whole other project ( my single turbo 93 Lexus SC300 ) the mustang almost was forgot about. i also have a set of iron gt40's off of a 93 cobra stored in box's.
ls1killa is offline
post #10 of 14 Old 06-22-2009, 06:23 PM Thread Starter
ls1killa's Avatar
i didn't install anything yet but the bottom end is built to run low comp. 8 to 1.
ls1killa is offline
post #11 of 14 Old 06-22-2009, 06:24 PM
Id sell both sets and get some kind of newer 64cc head. TF, or AFR, or canfield.
post #12 of 14 Old 06-22-2009, 06:34 PM
youll want a gassket in the 12cc range. All I could find was copper ones, IDK if you have the right RA for those.
post #13 of 14 Old 06-22-2009, 06:39 PM Thread Starter
ls1killa's Avatar
yah but, i wanna run some of the stuff that i have laying around just for now.
ls1killa is offline
post #14 of 14 Old 06-22-2009, 06:42 PM Thread Starter
ls1killa's Avatar
i will probably hit up powered by ford in orlando fl. for those gaskets since i live about 1hr. away.
ls1killa is offline
Do NGK R5673-8 spark plugs work with Edelbrock performer RPM Heads? Cld12pk2go 5.0/5.8 Engine Tech 0 12-08-2006 01:48 PM
edelbrock performer heads work done by foxlake $950 shipped welfare stang Windsor Engine Parts 5 04-21-2006 10:18 AM
how much compression could i lose going from 60cc heads to 70cc heads ??? red93notch 5.0/5.8 Engine Tech 2 12-25-2005 08:55 PM
1.72 cobra rockers work well on Eddy Performer 5.0 heads MattH2325 94/95 Tech 8 04-26-2005 01:13 AM
Will Edelbrock Performer RPM heads work on stock 95GT shortblock? Stangman306 94/95 Tech 10 03-09-2003 12:48 PM
