Stock block iron head w/ Hellion Kit - What's the deal with iron vs aluminum? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 06-13-2009, 02:03 AM Thread Starter
Coupester's Avatar
Trader Feedback: (41)
Hey guys, I'm planning a GT40P/ GT40 intake combo on a stock block, and a Hellion kit. Are aluminum heads absolutely crucial? I'm aware of the superior heat dissipation properties of aluminum, but will I be able to make 450rwhp safely with the iron stuff...
82 Mercury Capri - N/A AFR 165, FTI cam 11.99 @ 112
86 LX Coupe - Coyote, T56, 11.55 @ 121
Coupester is offline
post #2 of 6 Old 06-13-2009, 08:30 AM
We made well over 1000hp with N351 heads which were iron heads. Without really knowing much about the GT40P, I going to go out on a limb and say you are fine. I personally ran Dart Sr heads(cast iron) on a lot of different combos some turbocharged and some supercharged and they all made well over 450rwhp.
post #3 of 6 Old 06-13-2009, 09:12 AM
Make sure you get a good head gasket under there.
1993 Silver Coupe
8.25:1, F-303 cam, TFS Track Heats, BBK SSI Intake, 42lb inj, Tremec 3550, 3,73's, Pypes Exhaust, 03 Cobra brakes.
Hellion "Heat" kit - 66mm T-Trim w/GTK housing. 8lbs for now. (435hp/460tq)
HellionFox is offline
post #4 of 6 Old 06-13-2009, 09:15 AM
Yeah but you could say that about head gaskets and any head
post #5 of 6 Old 06-13-2009, 10:36 AM
red89coupe's Avatar
Trader Feedback: (31)
Iron is FINE.!!!! you can make enough power to split a stock block with a good iron head. prolly not a boat anchor like the E7 but that has nothing to do with being iron lol
no dyno but 3200lbs trapping 120+ (with 10psi) is ruffly 425ish with E7's and No issues (2yrs). have ran as much as 14psi on pump gas. stock motor oil pan to t/b but the E7s are slightly ported.
with a better head/intake and t/b 450 is easily doable safely
red89coupe is offline
post #6 of 6 Old 06-13-2009, 01:53 PM
rdub79's Avatar
Trader Feedback: (80)
X2, no issues here with the E7's, Felpro 8548PT-2 HG's and ARP head studs.
Best N/A pass was 8.44 @ 79 mph 1/8 mile, I picked up almost 1 second and 13 mph with the turbo on the stock motor.
88' Coupe
rdub79 is offline
Aluminum or Iron 4v Block? Yellow03Snake SVT & DOHC 8 04-18-2008 06:43 PM
stock unmachined block, iron heads, head gaskets? cleanLX 5.0/5.8 Engine Tech 20 11-26-2004 05:33 PM
aluminum vs. iron block weight 99281 5.0/5.8 Engine Tech 0 11-24-2004 05:21 PM
Cobra Aluminum Block vs GT Iron AZBlackBullitt GT & SOHC 4 01-01-2003 03:12 PM
Iron vs. Aluminum block sniperREM700 GT & SOHC 1 11-08-2002 02:59 AM
