Mounting gravity drain turbos in a low position? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 06-07-2009, 10:43 AM Thread Starter
BradleyRJ's Avatar
Trader Feedback: (25)
In the coming months I am going to start gathering parts to rebuild my turbo setup. Piping, new bov, possibly new FMIC.. etc etc.
Now my question is that since the turbos I am using, and would like to continue to use have a gravity feed for the oil drain back... If I mounted the turbo's lower than the oil pan, can I use a 12v pump to recirculate the oil back to the pan? Something similar to a setup like STS uses?
Where the turbos are now I don't like. I got the "kit" I am using at an UBER cheap price so I cant gripe to much about placement of fit.. but both purely suck and I want to clean it up quite a bit. I would like to place eac hturbo in front of the Fox GT foglight hole. The car DOES get driven on the street quite a bit and I would figure out some type of filter system for the air inlet but for now I just want to focus on can I mount them in a low position or not.
Just a few pictures to show what I want to clean up.
IF I cant mount them low I will still rebuild the kit and place the turbos in the typical Fox twin turbo setup locations, it will just be a lot cleaner under the hood.
Brad
They say what goes up must come down but I ain't reached my cruising altitude.
Take a look at what I did but can you imagine what I'm about to do.
BradleyRJ is offline
post #2 of 11 Old 06-07-2009, 09:47 PM
fred50stang's Avatar
I dont see why you couldnt. A lot of guys are doing that in the Cobra's that have twin turbos.
fred50stang is offline
post #3 of 11 Old 06-07-2009, 11:24 PM Thread Starter
BradleyRJ's Avatar
Anyone know what kind of return pump they are running?
post #4 of 11 Old 06-08-2009, 07:12 AM
toxic283's Avatar
I had used an inexpensive pump from Harbor Freight.
'86 GT 4.6 4V Turbo-SSO #2221. The Sponsors:
Ford Racing performance Parts-Jesse
Keystone Race Cars
Master security Corp East
toxic283 is offline
post #5 of 11 Old 06-08-2009, 07:10 PM
jman511115's Avatar
I've got that exact setup, the turbos are mounted low behind the bumpers. I use two of these pumps, along with a small tank under each turbo.
http://store.summitracing.com/partde...5&autoview=sku
64,999,987 firearms owners killed no one yesterday.
NRA member and you should be too! It's about more than just the guns. Join here.
https://membership.nrahq.org/forms/signup.asp?CampaignID=FrdmAssoc
jman511115 is offline
post #6 of 11 Old 06-08-2009, 09:38 PM
That is a pretty expensive pump. I have seen guys successfully use carb fuel pumps for this jump. I think the worry though is if those pumps have plastic internals and if they will hold up to the heat.
post #7 of 11 Old 06-09-2009, 12:48 AM
jman511115's Avatar
You get what you pay for...
post #8 of 11 Old 06-09-2009, 07:28 AM
Yeah, well I know people who have bought the more expense Weldon diff pumps for this and had them fail. Also know of people who have bought the same ones you have and had them fail. If there are examples of people running a $50 or so pump with success then why spend another $100 or so. Also everyone I know who is running low mounts just uses a single pump to handle both turbos and not dual pumps. So you do get what you pay for and sometimes you go overkill and overspend.
post #9 of 11 Old 06-09-2009, 10:43 AM
jman511115's Avatar
True. I'd prefer going with a pump designed for oil rather than fuel though.
post #10 of 11 Old 06-13-2009, 02:32 PM
LS2 KLR's Avatar
My turbos are in my bumper and had to run a scavenger pump as well. I originally bought a $200 pump from fastlane in houston but a yr later it got a slight crack in the "head" piece and dripped constantly. Unfortunately they started using a new pump specifically designed for turbo setups and couldn't get the part to fix it. However the new pump is $300. I ended up going to Harbor Freight and buying a $50 pump. I've had it for a yr but right now it has a very slow drip. I plan to see if I can find that turbo oil pump online somewhere cheaper. If not I'll just buy another cheap one.
LS2 KLR is offline
post #11 of 11 Old 06-15-2009, 07:41 PM
y2k02's Avatar
turbowerx pump is what I run along with a lot of the modular turbo cars.
2002 2V TF heads Custom Edelbrock NA SVT Cams
Twin 6466 TH400 Dominator EFI TH400 UCC
y2k02 is offline
mounting twin turbos eighty8gtfiveo General Mustang Tech 3 01-05-2008 12:39 PM
mounting twin turbos eighty8gtfiveo Turbochargers 1 01-05-2008 12:26 PM
oil drain position on S-Trim HuebyStang Superchargers 4 09-16-2005 07:48 PM
external pump mounting position tording General Mustang Tech 4 10-26-2003 09:29 PM
do you have to drain A/C system to replace low pressure switch? MYLITTLEHO General Mustang Tech 2 03-24-2003 09:35 AM
