MAF help! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 06-03-2009, 11:56 PM Thread Starter
jasonlx's Avatar
MAF help!
hey guy's, i'm lookin for some help with tuning my car. its a 93 lx with windsor jr's, track heat intake, custom cam, all supporting mod's and a hellion turbo kit (62-1).
i bought an abaco 85mm maf and am trying to tune the car myself. i tuned it for the 42# injectors i have and went for a drive, my wide band is pegged lean at idle but the car will water your eye's it smells so rich and while crusing its back firing through the intake the odd time or when i try to open the throttle much more then 1/4.
what i dont understand is while it smell's really rich at idle the wide band is dead lean. mabey its so rich its just dumping raw air and fuel out the exhaust? and also why would it be running lean at cruse if ts so rich at idle?
just lookin for some helpfull idea's guys, also if someone could post up a common maf transfer curve for 42#'s that would be a huge help. thanks for any reply's
jasonlx is offline
post #2 of 9 Old 06-04-2009, 01:10 PM
jturmanator's Avatar
Make sure your MAF is plugged in all the way. Mine did the same, the culpret was the MAF harness not plugged in completely. I'm running 60lb inj.
jturmanator is offline
post #3 of 9 Old 06-05-2009, 07:51 AM
lean will burn up your eyes and smell worse then rich does. I would trust the wide band over the nose any day if you are unsure maybe test it on another car or maybe find another one to try
Turbo 306,How fast will it go that depends on who is around.. Local parts pimp.. Things for sale most stuff is OBO https://docs.google.com/document/d/1hvqaA8aKICIw6BBj3IU2KCwiv86TtWXmxmvrsd8lw1A/edit?hl=en_US&pli=1#
wvstangdriver is offline
post #4 of 9 Old 06-05-2009, 02:26 PM Thread Starter
jasonlx's Avatar
thanks for the reply's
now this i didn't know, i recalibrated the wideband to be sure it was accurate and it still did the same thing. now that i know this i just may have it solved
jasonlx is offline
post #5 of 9 Old 06-05-2009, 06:57 PM
let us know how it works out
post #6 of 9 Old 06-05-2009, 11:11 PM Thread Starter
jasonlx's Avatar
so far i've gotten the car to work a little better, not as much fumes and eye burning lol. i have an innovate lc-1 wide band and no matter what i do at idle its pegged lean (22.4) has anyone ever had a problem like this? as soon as i touch the throttle its acts fairly normal. the cam shaft in the car is pretty lumpy sounding too, would this cause it to read really lean at only idle? it will sit there and idle all day long not a problem except that the wide band show's so lean. no matter what i do i cant get it to richen up the idle but everywhere else seems ok or close too it. thanks for the help so far guys, hopefully i can figure this out before i burn it
jasonlx is offline
post #7 of 9 Old 06-06-2009, 06:28 AM
what are you tuning with ? can you open the injector dwell at idle? they use to have mass air transfers on Pro-ms site I don't know if they do now or not. I think all I have is big injector stuff. I will look for you today.
post #8 of 9 Old 06-06-2009, 07:56 AM
mine does the same thing-but i had my car tuned-i think thats just what the lc1 does-when im driving it works like its supposed to and my tuner says as long as its workingexcept idle im fine
turbod89 is offline
post #9 of 9 Old 06-06-2009, 10:27 PM Thread Starter
jasonlx's Avatar
this seems to be exactly what mine is doing, no matter what i change the lc-1 shows the same at idle. mabey thats just how it works and im focused to much on that. the car seems to idle great (way better then with the c&l meter) i'll mess with it some more soon and let everyone know. thanks for the heads up turbod89.
jasonlx is offline
For Sale- 90mm ford lightning maf & maf extender Black 4.6 Beast Modular Engine Parts 3 11-13-2008 12:23 PM
FS: Stock MAF, Rubber Inlet Elbow & MAF Bracket - $75 EvinH Fuel System & Related 2 11-06-2007 08:50 PM
FS: Edelbrock Performer RPM, Pro-M Optimizer MAF, C&L MAF Andres2882 Windsor Engine Parts 2 06-01-2006 07:27 PM
What will happen if you swap a mass air sensor from a smaller maf into a larger maf? FHATTCATT EEC Tech 2 04-17-2005 04:51 AM
?'s about FMS Cobra Conversion 70MM MAF using stock MAF electronics... 91ConvLX 5.0/5.8 Engine Tech 2 12-12-2003 10:54 AM
