Thinking of going turbo - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 06-01-2009, 09:55 PM Thread Starter
8urzo6's Avatar
Well I am thinking of going turbo and selling my D1SC procharger kit.
What are the pros and cons of going turbo? I am looking at a Hellion turbo kit.
Are there any issues with the kit? I have a R blocked 331 with TFS 205cc heads, a victor 50 intake, and a CI TLSR. All of this in my 93 notch. Are there any issues with a T-56 trans? I also have a full MM suspension under the car.
Would it be worth switching? Thanks for the input in advance.
8urzo6 is offline
post #2 of 11 Old 06-01-2009, 10:17 PM
BFINCH's Avatar
you would have to re tune it for sure...
Originally Posted by 84lxconvertible
For such an educated guy reading comprehension isn't your strong point.
BFINCH is offline
post #3 of 11 Old 06-02-2009, 03:21 AM
hotordder_101's Avatar
If you don't already have a two step get one. That way you can build boost at the line with a stick.
Luke
'94 F350 Crewcab dually 7.3 Turbo (Not Powerstroke) Deisel CLEAN
'89 Ranger 2.3 5spd Work Truck
hotordder_101 is offline
post #4 of 11 Old 06-02-2009, 03:31 AM
With these two statements...I doub't he is super worried about building boost at the starting line.
Icey101 is offline
post #5 of 11 Old 06-02-2009, 03:33 AM
Why you say that?
Luke
post #6 of 11 Old 06-02-2009, 07:24 AM
MIKE92NOTCH's Avatar
you need to do a lot of research and see what's really out there. check out similar combos to see the power made and other parts they're using, etc. i'd also suggest B&G Custom Turbo way before hellion. hellion makes a nice beginner's kit for fox's. but with your potential, b&g will give you a setup to make over 1k hp. give brian a call there and see what i mean by a great business
also, is your t56 a viper spec? if not, it's time to upgrade. but i'd also suggest going auto with the power you can make. anything over 650 and up is too much to handle for a manual in my opinion. especially on the street.
95 Crystal White GT
8.50 chassis with a 12 something drivetrain
MIKE92NOTCH is offline
post #7 of 11 Old 06-03-2009, 04:34 PM
Hellion is not a bad kit, greatly depends on the power goals of course. If maxing out a T76 is not enough power then I would look elsewhere. The T56 should not be an issue because it sounds like they have moved their crossover to the front of the motor. No idea on if any of the MM suspension would cause issues. I'd contact Hellion, chances are they would know.
post #8 of 11 Old 06-03-2009, 05:41 PM
Erich's Avatar
You will make power alot quicker with a turbo. My two cars are about as extreme as you can get as far as differences. Both are fun to drive. But with the 4V and the D1 you need to tach it up good to really get the representative major acceleration. The turbo setup is making power at 1500 rpm.
Erich
Erich is offline
post #9 of 11 Old 06-03-2009, 06:34 PM
R blocked 331s are called 4V these days?
post #10 of 11 Old 06-04-2009, 06:59 AM
ssj50driver's Avatar
I believe Erich is talking about his 97gt being an extreme case from his 2 valve 5.0 with diy twins. With his mark 8 being a 4 valve that he put in his 97 gt versus his 5.0 based twin turbo ride. No offense.
ssj50driver is offline
post #11 of 11 Old 06-04-2009, 08:50 AM
That is not a fair comparisons though, the 331 if built properly will make up for the low end umpth that I presume a stock 4V has. Sure a turbo still is a whole different animal on a 331 v. the D1 but how what I assume is a stock 4V drives with a supercharger compared to a built 331 with a supercharger is like comparing apples to oranges.
Depending on what the car is actually used for it would be hard to say if it is "worth switching". Yes the turbo route would produce a good bit more power and give a different power band that many prefer. It would though be a lot trickier to drive with a standard trans if one were to actually tune it to take advantage of that added power. I have had both, while never a D1 though and instead Vorturds, I actually prefer the superchargers for cars I actually drive but that is just me.
thinking about turbo crazygn Turbochargers 5 09-14-2006 01:58 AM
thinking turbo??? schmidty1284 Turbochargers 3 12-18-2005 10:36 PM
thinking about going turbo! bdub_02 Turbochargers 12 11-14-2005 02:07 PM
Thinking about going turbo? GTWayne95 94/95 Tech 9 03-23-2004 01:24 PM
Thinking of going turbo Tra2xx Turbochargers 3 09-09-2002 11:03 PM
