C&L meter - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-29-2009, 07:55 PM Thread Starter
Thomas331's Avatar
Trader Feedback: (22)
C&L meter
Just wanted to know who else is running a c&l draw through meter as a blow through? How good does it work? I called c&l and they said that my 76mm sensor will work as a blow through, just that it may peg the voltage on the meter at a lower hp level then I would have to have the car tuned to get it right, not sure what that means. Neways im ordering a turbo kit real soon, not sure who from, just wanted to know if the meter I have would really work right. Thanks for the advise.
Thomas331 is offline
post #2 of 6 Old 05-29-2009, 08:28 PM
I'm going to try and use it.. we'll see what happens. If I were you I'd sell it and just get a PMAS blow through cal'd for your setup.. I still may end up doing that if it pegs the maf, but if you can get the driveability down you can always get a Diablosport MAF extender, which will make sure the voltage doesn't peg on the MAF.
ChaseGT is offline
post #3 of 6 Old 05-30-2009, 08:00 PM Thread Starter
Thomas331's Avatar
Exclamation
I talked with c&l, the company I am purchasing the turbo kit from and the guy that is going to tune it and they all said there will be no problem using it, so I guess that saves me some coin. If anyone else has the same questions, I will let you know how it runs and if there was a lot of tuning involved to get it right.
post #4 of 6 Old 05-30-2009, 10:56 PM
staticstang's Avatar
I've got a c&l on my car. It has done a pretty good job and wasn't that hard to tune.
staticstang is offline
post #5 of 6 Old 06-04-2009, 01:37 PM
The only tuning problems that I had with my car were related to the C&L. The PMAS cleared them right up
1993 Silver Coupe
8.25:1, F-303 cam, TFS Track Heats, BBK SSI Intake, 42lb inj, Tremec 3550, 3,73's, Pypes Exhaust, 03 Cobra brakes.
Hellion "Heat" kit - 66mm T-Trim w/GTK housing. 8lbs for now. (435hp/460tq)
HellionFox is offline
post #6 of 6 Old 06-10-2009, 01:22 PM
I have used C&L on all my turbo cars, just make sure it is imbetween the TB and the BOV. not before the BOV, it will not work, has to be imbetween
project tt is offline
C&L meter & cobra meter tommygun Fuel System & Related 2 01-22-2007 03:29 PM
C&L 76mm meter w/24lb & 30lb sampling tubes for sale scott88 Windsor Engine Parts 3 09-29-2005 09:51 AM
C&L 76mm Tube and Meter...do I use stock meter bracket or omit it? 89WhiteGTRagtop General Mustang Tech 7 09-27-2004 11:45 PM
C&L 76mm Tube and Meter...do I use stock meter bracket or omit it? 89WhiteGTRagtop General Mustang Tech 1 09-15-2004 11:26 AM
Confused with C&L air meter. Do I need to buy a new meter? 89WhiteGTRagtop General Mustang Tech 5 07-09-2004 06:34 PM
