How to hook up MBC properly to Tial 38mm Gate? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 05-27-2009, 09:05 AM Thread Starter
Rich G's Avatar
Trader Feedback: (35)
I got a MBC with 2 ports, 1 in and 1 out.
It woulkd make sense to me for it to just intercept the line going to the gate, however I have read that some people use the top port on the MBC and tee it off somehow.
I cant find info anywhere, turbomustangs is about useless.. only info I found was through google on ricer sites but no definitive answers
On a side note can I run it into the car with real long vacuum lines?
Rich G is offline
post #2 of 7 Old 05-27-2009, 10:31 AM
If you got to the instillation diagram, you will see.
http://www.tialsport.com/techincal.htm
You hook up the bottom port of the mbc to the side of the wg. Then the side of the mbc goes to the top of the wg. That way the spring is being pushed down in the wg.
You have to T it into the source too.
This is what I have read, I have not put mine on yet.
1994 Turbo GT
mustangless is offline
post #3 of 7 Old 05-27-2009, 11:15 AM
mbricher's Avatar
Mine goes from the turbo housing to MBC. Then from the MBC to the side port on my Tial WG. Top port is left open on the WG.
1990 Mustang GT
Dart IE 363, PT78 HPS, Built 4R70W, BS3, BBRC Fuel system, TeamZ, ect.....
Tuned by Bob Kurgan
mbricher is offline
post #4 of 7 Old 05-27-2009, 11:17 AM Thread Starter
Rich G's Avatar
Thats what I think I am gonna do.. the instructions that came with it say that very vaguely
Rich G is offline
post #5 of 7 Old 05-27-2009, 11:19 AM
Authorized corral.net Commerical Poster - Exp 4/2010
RealStreetPerformance's Avatar
Bleeding air from the bottom or adding air to the top of the gate will add boost.
Jay Meagher
Sales, Installations, Dyno, Fabrication, Engine Builds
850 N US HWY 17-92
Longwood, FL 32750
RealStreetPerformance is offline
post #6 of 7 Old 05-27-2009, 06:19 PM
Bobo's Avatar
Originally Posted by mustangless View Post
What is the point 'f the "vent" drawn between the MBC and top of the wg? Maybe they just mean leave it vented if not using a MBC?
Is there a purpose for a one way check valve in there somewhere? Maybe it's not on the MBC, but I remember the need for one somewhere in the vacuum lines. Trying to get all my thoughts together before my install.
Scotty we need more power!!!
Bobo is offline
post #7 of 7 Old 05-27-2009, 10:35 PM
My turbonetics/home depot MBC says to:
1. use a boost-referenced port before the butterflies and T it.
2. One side goes to the bottom of the wastegate, the other to the MBC
3. the output of the MBC goes to the top of the wastegate.
it just depends on what you believe is more "safe" I guess. Bleeding off boost and venting the wastegate or using boost pressure on both sides of the spring in the wastegate.
streetfalcon is offline
stinger header and ext 38mm gate greenbullitt 2.3L Engine Parts 2 02-20-2009 11:57 AM
70mm Turbo, 38mm Waste gate w/ Intercooler svt3565 Power Adders 4 11-16-2008 12:48 PM
Trade My brandnew Turbosmart Ultra Gate 38mm for you Tial sport WG 38mm 93gtman Power Adders 0 03-26-2008 05:58 PM
tial 38mm wastegate fl stang Power Adders 6 06-15-2006 10:30 AM
Tial 38mm wastegate Casper2345gt Power Adders 1 02-13-2005 12:06 PM
