from supercharger to turbo need help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 05-24-2009, 10:42 PM Thread Starter
i was running a powerdyne supercharger only running 8 lbs of boost no inner cooler now i went to turbo with inner cooler would i need to change anything in my tuning i have 45 lb injectors i have a 9 to 1 comp. motor now that i am running a inner cooler how many pounds of boost can i run i have felpro multi layer headgaskets
superchargedmustang is offline
post #2 of 8 Old 05-24-2009, 11:42 PM
biminiLX's Avatar
Even at the same boost pressure they turbo will flow a different amount of air than the supercharger and have a different boost curve, so yes you'll need to change the tune.
As far as how much boost you can run with MLS gaskets that depends on a bunch of stuff, what parts and turbo do you have? Need a lot more info. to really help you out.
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #3 of 8 Old 05-25-2009, 09:45 AM Thread Starter
what kind of tuning will i need to do i have found that where i had the vaccum line hooked for the supercharger wont work with the turbo the car wont idle for sh*t when i unhook one of the vaccum it will then stop missing and idle the vaccum line has a small black canister with a t hooked to it and a electical plug on the other end of it not sure what this is .
as far as tuning the only guys i know that do tuning here in michigan is pauls performance but i cant afford 2000 dollars for them to tune it any other suggestions thanks
post #4 of 8 Old 05-25-2009, 11:02 AM
Rich G's Avatar
Trader Feedback: (35)
I doubt they charge 2000 to tune, and you still didnt answer the questions he asked
Rich G is offline
post #5 of 8 Old 05-25-2009, 10:50 PM
biminiLX's Avatar
Lidio at Alternative Auto for tuning but call and talk to him first.Yes, still lots of questions before real advice.
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #6 of 8 Old 05-25-2009, 11:05 PM Thread Starter
biminilx tell me what kind of parts you need to know with the supercharger i was running to fuel pumps a 255 in the tank and a big inline pump 45 lb injecters, a 61 trim turbo i think it is turbotronics it is the kit that boostbrothers build and sell go to boostbrothers.com have a 75 mm elda throt.body, i think i have a 70 mm maf holly systemax intake i have a mallory hyfire 6 ignition system now right now i dont have my o2 sensor hookup and i drove my car abought 5 miles and now it is missing bad is it because i dont have the o2 sensors hookup and fouled out my plugs please please help me what do i need to buy to tune it someone said somthing about a wide band o2 sensor
post #7 of 8 Old 05-28-2009, 10:24 AM
biminiLX's Avatar
All your parts sound fine, I would seriously consider spending the money and having a professional tune it for you before you hurt the motor. You don't necessarily need an expensive stand-alone like FAST as an SCT chip in the stock computer can work but a wide-band standalone is best.
Call Lidio or Bob Kurgan (good guy on here, just search) and talk to them.
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #8 of 8 Old 05-31-2009, 09:25 AM
red89coupe's Avatar
Trader Feedback: (31)
what BRAND is your maf ??? draw threw or blow threw setup???
red89coupe is offline
supercharger or turbo? breakinparts Superchargers 23 01-25-2005 11:17 AM
Turbo Or Supercharger teebo95 94/95 Tech 10 09-20-2004 01:04 PM
same exact engine... supercharger vs turbo... how much more hp will the turbo make? PUR PONY 5.0/5.8 Engine Tech 14 01-14-2004 12:05 AM
