2-step stick guys here? have questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 31 Old 05-19-2009, 10:13 PM Thread Starter
biminiLX's Avatar
Hey guys, I've never had a 2-step but think I understand how it works and I think it would help my high-power stick car.
Does anyone here use one with a stick car?
Can XFI have any 2-step control?
I think I'd like to arm the system by switch (does it have to be a momentary?) and have it disengage when I release the clutch.
Does that sound right?
Any advice appreciated.
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #2 of 31 Old 05-19-2009, 10:18 PM
gtdroptop's Avatar
Trader Feedback: (22)
I dont know about the XFI but I have the Mallory Hy-fire 6 with a built in 2 step. I have mine set up on a momentary button that also controls the line lock. The 2 step has a toggle so I can still use the button when doing my burnout and then switch it on to hold me at the line. I also have the corded buttons going into a 12volt acc. outlet so when Im not racing the button stays in the glove box. I did that more for the safety issue......My wife is a blonde.....enough said!!! lol
84 GT T-top, 306 GT40P 5 spd. Trick Flow stage 1 cam, 1.6 roller rockers, Edlebrock RPM Air Gap, BG Speed Demon 650, Mallory ignition, Full Mac exhaust, FRPP driveshaft, UPR pro rear suspension, Moroso drag springs, Lakewood struts/shocks, SOS anti roll bar, 4 point roll bar, 3100lbs with me!!!!
gtdroptop is offline
post #3 of 31 Old 05-20-2009, 05:06 PM
For a turbo 5 speed, it is the way. Don't know about xfi, I use msd's 2 step wired to trigger off left horn button to keep right ready to shift quickly.
High_Voltage is offline
post #4 of 31 Old 05-20-2009, 05:23 PM
i also use the horn..
AMF_Racing is offline
post #5 of 31 Old 05-20-2009, 09:22 PM
red89coupe's Avatar
Trader Feedback: (31)
I ran a MSD digital 6plus and could build full boost (10psi) at the line. I had to pull a few degrees of timing to get the full 10psi with it set at 3500rpm
I run a momentary switch and the clutch switch to a relay.. push clutch in,push momentary and 2 step is on... turns off once you release the clutch and dont come back on until both the clutch and momentary are pushed in together again.
its nice to have NO buttons to mess with, tried cruise control, windshield washer button and horn. this is much nicer and it dont put the car on the 2step between shifts like running it off JUST the clutch switch.
red89coupe is offline
post #6 of 31 Old 05-21-2009, 07:40 PM Thread Starter
biminiLX's Avatar
Excellent sounds like what I want.
Just to clarify, you hit the momentary switch, push clutch in, let off momentary switch and then hit throttle to get on 2-step then the 2-step releases when you release the clutch?
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #7 of 31 Old 05-21-2009, 08:14 PM
red89coupe's Avatar
-J
yep thats exactly it.. except for some reason I do clutch first lol lol lol..
post #8 of 31 Old 05-21-2009, 09:18 PM
staticstang's Avatar
I've got mine on a momentary switch that is on my shifter ball. I used to use it for nitrous, but now its a 2step. I would like to run the switch in series w/ a clutch switch. I keep forgetting to let go of the 2step after I launch the car and then the thing falls on its face about 20ft out(hitting the limiter).
staticstang is offline
post #9 of 31 Old 05-21-2009, 09:26 PM
jturmanator's Avatar
Got mine going FINALLY! I only can build maybe 4lbs at 3000 rpms. Dont work to well on the street! LOL
Momentary push button using a relay and clutch switch is the only way to go. You push the pedal down, tap the momentary switch, floor it, then take off!
jturmanator is offline
post #10 of 31 Old 05-21-2009, 09:53 PM
any one could post a wiring diagram of the momentary switch, relay and clutch??
Turbomustang
Mesarina is offline
post #11 of 31 Old 05-21-2009, 10:31 PM
red89coupe's Avatar
post #12 of 31 Old 11-07-2009, 07:16 PM
wildstang41's Avatar
Just did my car and works grate, thanks just what I needed. Now just got to get the nitrous to work like that.
wildstang41 is offline
post #13 of 31 Old 11-07-2009, 10:23 PM
my8950's Avatar
I'm wondering why these wiring diagrams that get posted always say no line lock...Doesn't anyone with a stick use a line lock and a 2 step? Strange...
my8950 is offline
post #14 of 31 Old 11-07-2009, 11:26 PM
Rich G's Avatar
Trader Feedback: (35)
There is a really good thread detailing how to do a 2step using the stock clutch wiring and allowing it to release when you let the clutch out.. It uses a relay etc to make it happen
Rich G is offline
post #15 of 31 Old 11-08-2009, 04:40 PM Thread Starter
biminiLX's Avatar
Yes and that is how I have mine set-up. Both the 2-step and launch setting of the AMS 500 releases when the clutch come out.
I also have a line-lock but have no need to wire it with the 2-step on a manual.
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #16 of 31 Old 11-08-2009, 09:57 PM
pkstang's Avatar
Trader Feedback: (161)
https://forums.corral.net/forums/show...highlight=step
-J
whats the point of wiring in the line lock... in case the car rolls out and breaks the lights or is there soemthing else to it
pkstang is offline
post #17 of 31 Old 11-08-2009, 10:00 PM
Rich G's Avatar
thats the only thing I can see it used for, I mean I guess u could use it for the burnout but......
Rich G is offline
post #18 of 31 Old 11-08-2009, 10:39 PM Thread Starter
biminiLX's Avatar
If you race on uneven starting line tracks some guys need it.
You can do a 3-step as a burnout rev limiter with the line-lock but I don't see the point.
-J
'91 LX hatch
Bimini Blue
427"/88mm at 16 psi
biminiLX is offline
post #19 of 31 Old 11-08-2009, 11:03 PM
This is going to sound really ignorant. Please don't flame me.
How does a 2-step let you build boost? Does hitting the rev limiter act like an anti-lag?
gijosh28 is offline
post #20 of 31 Old 11-09-2009, 05:38 AM
Rich G's Avatar
It allows you to hold the pedal to the flooor and also loads the motor
Rich G is offline
post #21 of 31 Old 11-10-2009, 07:24 PM
Trader Feedback: (15)
so the bypass valve doesnt open
93 SC Coupe Best ET [email protected] - SOLD
96 Cobra - Xpipe, 2 chambers, K&N, 4:30s [email protected]
sick96gt is offline
post #22 of 31 Old 11-10-2009, 09:09 PM
danny carvalho's Avatar
Subscr.
One owner 50,000 miles Dart 363, oliver rods, Karl's East Coast custom Y2k 82mm turbonetics, TW stage 2 Fox Lake, PMS, Victor intake, PMAS custom pipe for 85 lb/hr inj. T56 Magnum 6 speed w/Spec3+,756 rwhp 746 tq (pump gas, 14psi, 20*) 840 rwhp 848 tq (race gas, 16.5psi, 20*) SOLD
-2014GT/CS
danny carvalho is offline
post #23 of 31 Old 11-15-2009, 01:19 AM
04Ryan's Avatar
It works by shutting off spark to alternating cylinders to maintain the rpm you set it for..which your injectors are still firing. Which all that fuel and oxygen is then sent out of the exhaust valve and into your exhaust system feeding the turbo. When that cylinder fires next time it lights off the fuel and air mixture in the exhaust creating a "false" load. Which the sudden rush of heat and exhaust velocity from the combustion happening in the exhuast pipe in turn spools the turbo! Very simple and effective...but if you stay on it too long you could damage some things.
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #24 of 31 Old 11-15-2009, 08:30 AM
pkstang's Avatar
Question
how and what?
pkstang is offline
post #25 of 31 Old 11-15-2009, 12:16 PM
04Ryan's Avatar
how and what?
Well since the combustion process is now taking place inside your exhaust system...which wasn't made to handle the extreme temps of the combustion process. It'll turn your manifolds cherry red in no time..which is rough on exhaust valves and guides. And depending on how far away your turbo is it could start to melt the tips of the turbine wheel. But in the Mustang world that would only apply to the guys running the low mount twins that bolt right to a exhaust manifold. Those of us with the turbo mounted up front wouldn't have to worry about that. But it is hell on headers and valves...after you trip the second stage light and load up on the 2 step that little bit till the last yellow comes on isn't long enough to do damage...obviously since tons of people have been doing it forever. It's just not something I would be doing all the time just to show some friends on the street since the chance you could be on it too long is greater.
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #26 of 31 Old 11-15-2009, 02:08 PM
Thanks for the info. I have been hesitant to get a 2 step becuase I just ddint know all this.
gijosh28 is offline
post #27 of 31 Old 11-15-2009, 03:04 PM
04Ryan's Avatar
Yea they work great...and no reason to be scared of one. Just play it smart and use it for what it's designed for.
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
post #28 of 31 Old 11-18-2009, 06:06 AM
My common problem with my momentary switch, is i always forget to let go of it. I have done that so many times....Sooo aggravating...
JBIGBOOTSY is offline
post #29 of 31 Old 11-18-2009, 03:06 PM
red89coupe's Avatar
lol.. I know what ya mean lol it really sounds like something is gonna come apart.
with my car I can build 5-6 psi on just the 2 step and when I pull 4* of timing while on the 2 step it builds a full 9 psi. the more boost you make the worse it sounds lol
post #30 of 31 Old 11-18-2009, 03:43 PM
not to thread jack but i have been looking at the msd launch master for mod motors has anyone ever used one of these and do they work good
98slowstang is offline
post #31 of 31 Old 11-18-2009, 07:27 PM
04Ryan's Avatar
I was at a Fun Ford event one year and it was time for all the Pro 5.0 guys to run. And the announcer came on and said "Time for the big boys with their big toys...the ones that sound like an EXTERNAL combustion engine at the starting line!" I got a kick outta that one..
But they do sound like they are literally blowing up right in front of you...then that last yellow would come on and all of a sudden 2k HP went flying down the track! I always did love watching them boys...
1992 2V Notch
S-Trim 14lbs
[email protected]
04Ryan is offline
stick guys need your help with clutch and tb problem 8urvtec Drag Racing 5 03-10-2009 10:14 AM
Stick Guys!! Simple Questions slow302 Drag Racing 24 09-17-2008 12:08 AM
2 step with a stick shift question Martin Connelley Drag Racing 8 02-07-2008 01:47 PM
pure street guys ,Need advice on installing a 2 step on a stick car. flyin2jz General Mustang Tech 5 12-26-2006 09:39 AM
2 step with a stick DSmith General Mustang Tech 2 02-21-2006 08:07 PM
