89 Notch 306 BG hotside custom coldside MPT70 SLEEPER - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 52 Old 05-18-2009, 08:54 PM Thread Starter
orion_134's Avatar
Trader Feedback: (126)
89 notch
Engine specs:
306 with Fcam, Trick Flow Twisted Wedge heads, TFS 1.6 RR, TFS 18cc dish pistons, Vic Jr intake, 650dp carb
Fuel system:
A1000 through -10 feed/return and A1000 regulator
Ignition:
Crane HI-6 with TRC boost retard and optical pickup distributor with dial-adjustable advance curves and digital 3 stage rev limiter
Power adder specs:
EV hat, 3" coldside through a a2w intercooler, BG CUSTOM TURBO hotside, Master Power T70 with a 3.5" DIY downpipe y'd into dual 2.5" flowmasters (I know...but I can sacrifice power for quiet, X02 44mm v-banded wastegate with 12# spring.
Chassis:
QA1 coilover and k-member front kit, Pro3i lowers, Baseline uppers, QA1 adjustable shocks, 4 cyl rear springs, subframes, torque box reinforcements
Drivetrain:
4R70W with Lentech full manual valvebody, Edge 3000 stall lockup converter, 31 spline axles and Exploder trac-loc
Power steering, AC, and overdrive
First startup was yesterday...sounds mean with the Fcam through a single 3.5" exhaust. That dp was a beeotch to fit past the headers, accumulator, starter, bell, etc....but it works and it fits. Put a vband right by the #4 primary so that I can remove the section of downpipe to access the plugs. To top it off, it was made out of some leftover diesel exhaust :welder:
Now I just need to finish running the exhaust to the rear of the car, plumb the wastegate, figure out what I am going to do about an air filter, relocate to regulator from the strut tower to the firewall so it is not right on top of the header, tie up the odds and ends and she should be rolling! No more non-running turbo stang! Hopefully I will get pics soon, I just need to find my camera charger...
Update: 5/18/09
Block got cracked from a hard freeze while I was out of country on business and had no antifeeze (again, I know) and I was in the middle of a cam/lifter swap because I had a lifter go out and wipe the cam. Repaired what I thought was external water passage crack on back of block and went for test drive and lost most oil pressure, so looks like a stock explorer shortblock is going in reringed/bearing'd and insert fcam What d'yall think?
I know, it needs a wetsanding, some new rims, finish aligning bumper cover, engine is being painted when I yank the engine, run the intercooler lines and tune!
Thanks for the help guys,
Jesse
FOR SALE! 89 LX Coupe: 306, TFTW, F303, Vic Jr, 750dp, T70 at 14#, 4R70W 3k Edge, 3.73's, QA1, Pro3i, Baseline, Crane
AC, PS, Street Car!
7# times: 1.56 [email protected] [email protected]
SSGT USMC Infantry 3x Veteran
orion_134 is offline
post #2 of 52 Old 05-19-2009, 10:22 AM
Trader Feedback: (43)
would look alot better if you man handled that engine bay and stripped alot of the #### you dont need and paint the ####er!
btw it should be enough torque to scare the #### outta you
Precision 67mm turbo, this and that.
Thewhite88pony is offline
post #3 of 52 Old 05-19-2009, 11:38 AM Thread Starter
orion_134's Avatar
I need everything in that engine bay...ie, not getting rid of heat or ac. I already commented that I am going to paint the engine bay.
Jesse
AC, PS, Street Car!
post #4 of 52 Old 05-19-2009, 11:40 AM
right on, i would get rid of alot of #### but its your race car!
turbo car dont need heat or AC
post #5 of 52 Old 05-19-2009, 11:45 AM
89 LX Coupe: 306, TFTW, F303, Vic Jr, 650dp, T70, 4R70W 3k Edge, 3.73's, QA1, Pro3i, Baseline, Crane
AC, PS, Street Car!
Where do you see race car? :P
ChaseGT is offline
post #6 of 52 Old 05-19-2009, 11:50 AM
ssj50driver's Avatar
Good stuff B&G's the SH!*!
ssj50driver is offline
post #7 of 52 Old 05-19-2009, 12:57 PM
automatic turbo car with a carb
race car
post #8 of 52 Old 05-20-2009, 06:37 AM Thread Starter
orion_134's Avatar
Just because it can race doesn't make it a race car
AC, PS, Street Car!
post #9 of 52 Old 05-20-2009, 06:03 PM
mustanggtrider's Avatar
I always thought it came down to the driver or at lest 50/50
mustanggtrider is offline
post #10 of 52 Old 05-20-2009, 06:05 PM
dustang's Avatar
really dig the car man!!!
cool
1988 GT TT project, 1988 UHP NOVI2k coupe.
dustang is offline
post #11 of 52 Old 05-20-2009, 07:21 PM
privatejoker's Avatar
Most sleepers don't have pin on hoods or "sleeper" written on them.
privatejoker is offline
post #12 of 52 Old 05-20-2009, 07:26 PM
cool car sleeper or not.
Zeet's5.0 is offline
post #13 of 52 Old 05-20-2009, 08:29 PM Thread Starter
orion_134's Avatar
Yep...you caught me...it really isn't a sleeper...thanks for changing my mind, I'll change the thread to read "all out dragcar".
As for the rest of you...thanks for the support, that's what I needed, a little motivation to complete it!
AC, PS, Street Car!
post #14 of 52 Old 05-25-2009, 09:12 PM Thread Starter
orion_134's Avatar
Just got a replacement Explorer engine for the shortblock. Going to paint the engine bay, paint/wrap the headers and downpipe, rering/bearing the engine, paint some accessories under the hood, reassemble and start tuning. Yay...
AC, PS, Street Car!
post #15 of 52 Old 05-25-2009, 10:14 PM
97SVT's Avatar
you paint or powder coat the draglites? I though about doing that to mine
1967 Mustang Coupe
1990 Mustang GT Turbod DD
1987 Mustang GT Turbod-9.75 @ 140mph gone but not forgotten
97SVT is offline
post #16 of 52 Old 05-26-2009, 05:35 AM Thread Starter
orion_134's Avatar
a la rattlecan
AC, PS, Street Car!
post #17 of 52 Old 05-26-2009, 09:41 PM
who converted the carb?
streetfalcon is offline
post #18 of 52 Old 05-26-2009, 09:43 PM Thread Starter
orion_134's Avatar
I did per the instructions on theturboforum. It's rather easy, not much to do if you know your way around a carb and can drill a few holes.
Jesse
AC, PS, Street Car!
post #19 of 52 Old 05-26-2009, 11:29 PM
EvilTwistedTwins's Avatar
just wondering how much boost you plan on running with that 650 holley?
"Nitrous is like hot girl with with STD's. You know you wanna hit it, but your afraid of the consequences."
EvilTwistedTwins is offline
post #20 of 52 Old 05-27-2009, 05:37 AM Thread Starter
orion_134's Avatar
12ish depending on the wastegate
AC, PS, Street Car!
post #21 of 52 Old 05-27-2009, 10:37 PM
Jesse
I guess you are referring to the hanger18fabrication page.
what jets are in it?
what size did you drill the PVCRs to?
brpv?
vent tube extensions?
post #22 of 52 Old 05-27-2009, 11:07 PM
Do you think that 650 is enough carb for that engine with that much boost?
also wondering the same questions streetfalcon asked
post #23 of 52 Old 05-28-2009, 05:10 AM Thread Starter
orion_134's Avatar
Yes, the 650 will be plenty. PVCR in the front is ~5/64" if I recall correctly, vent tube extensions, no BRPV as of yet (not running, but prepared to make one if I have to) and the jets are the same from my supercharged setup I think 76/88...but all that is subject to change now that it's turbo'd.
Jesse
AC, PS, Street Car!
post #24 of 52 Old 05-28-2009, 07:00 AM
USMC50LX's Avatar
Trader Feedback: (38)
Its about time you got a thread up with pics! Wish I could have been there for the start up.
Your mom goes to college.
USMC50LX is offline
post #25 of 52 Old 06-10-2009, 01:26 PM
USMC50LX's Avatar
Hey, I saw the shortblock at the hobby shop. Whens it going in?
USMC50LX is offline
post #26 of 52 Old 06-10-2009, 05:34 PM Thread Starter
orion_134's Avatar
July 4th weekend. Go ahead and get it started for me while I'm at Benning
AC, PS, Street Car!
post #27 of 52 Old 06-10-2009, 07:50 PM
USMC50LX's Avatar
Yaaaaa...
BTW, I'll be gone by then. I checkout the 2nd. Guess I'll have to settle for pics from now on.
Have you heard from Preston?
USMC50LX is offline
post #28 of 52 Old 06-14-2009, 07:42 PM Thread Starter
orion_134's Avatar
Gone huh, that sucks. Yeah, hit him up on global.
Back on topic, will be rebuilding the engine, painting the engine bay, painting/wrapping the headers and putting it all back together July 4th weekend.
Jesse
AC, PS, Street Car!
post #29 of 52 Old 06-15-2009, 10:14 AM
USMC50LX's Avatar
Hey BTW, whats that turbo rated to for HP? I was thinking about one of these kits for when I get back.
USMC50LX is offline
post #30 of 52 Old 06-15-2009, 12:46 PM Thread Starter
orion_134's Avatar
Enough to break a stock block. I've seen 650 rw out of it as a single, double it for a twin on a big cube windsor
AC, PS, Street Car!
post #31 of 52 Old 07-09-2009, 10:52 PM Thread Starter
orion_134's Avatar
Pulled the old engine and the old broken lifter's needlebearings had been sucked into the oil pump and every bearing was trash. Luckily the cam was spared. I just took the 100k shortblock and slapped my cam and a new oil pump in it and dropped it in. I was rushed so I didn't paint the engine bay, but I did get the headers bead blasted, four thickcoats of the VHT paint, wrapped, and then silicone-sealed...hopefully it'll keep the heat down underhood. Away on business until the end of the month but once I return I will finish it up, freshen the carb and resume tuning.
Jesse
AC, PS, Street Car!
post #32 of 52 Old 07-23-2009, 01:31 AM
speedo's Avatar
Sweet build!
90 5.0 GT
Old setup- Edlebrock RPM intake, Performer heads, Vortech A-trim, Mac headers, 70TB, MSD Ignition, FMS E-303 cam, T56, 4.10s,
11.84 @ 113 1.64 60' Dynoed 428hp 419tq
New Combo 360 Dart block, solid roller cam, Vortech YSI, sheetmetal intake
speedo is offline
post #33 of 52 Old 07-23-2009, 05:56 AM
Rich G's Avatar
Trader Feedback: (35)
Cool car but definitly not a sleeper
Rich G is offline
post #34 of 52 Old 07-23-2009, 05:29 PM
Cars that say "sleeper" on them, cant be considered a sleeper anymore!
Thats like a undercover cop trying to buy drugs, with a sheriff badge and hat.
JBIGBOOTSY is offline
post #35 of 52 Old 07-23-2009, 05:41 PM
I give you props for doing it all yourself.
The only thing I question is the size of your air to water cooler..... it may be a little on the small side for your project.
Nothing but slow chebby's right now.....
OrangeSVT03 is offline
92 Notch BG CUSTOM TURBO Hotside Custom Coldside(Link to Turbomustangs) 93gtman Turbochargers 10 05-08-2008 06:48 AM
89 Notch 306 B&G hotside custom coldside MPT70 orion_134 Turbochargers 8 04-07-2008 10:11 PM
F/S 94-95 single turbo hotside and coldside only for cheap ! Sinful Power Adders 7 09-21-2006 08:41 PM
Custom Hotside Turbo kit with FMIC Fash00 Power Adders 11 09-20-2006 06:59 PM
FS: 88 Notch - custom paint, draglites,306 shortblock - chicago, IL Fast5pointSlow Mustangs For Sale/Wanted, 1987-1993 18 12-15-2005 01:18 PM
