gear selection - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 05-17-2009, 11:20 PM Thread Starter
gear selection
hey all my setup consist of a bandg turbo kit with a 70mm turbo with a .68 exaust housing. the motor is a 9.5.1 bottom end and pretty much stock cobra upper with stock gt40 heads, stock cobra intake ported with all the bolt ons. i have 3.73 now and i am wondering what i should put in it if i am running a maxiumm of 10 pounds. ohh ya i also have a 5 speed
New Setup: 5.0 Coyote Swap, LTs, JLT, Tune. 435 rwhp 419 rwtq. 11.365 @ 121mph on NT05.
Old Setup: 306 forged bottom end, stock gt40 heads, 1.7s stock cobra intake, e- cam and bolt ons 275rwhp and 315 rwtq on a break in tune
sneaky94cobra is offline
post #2 of 7 Old 05-18-2009, 08:49 AM
ssj50driver's Avatar
Usually the 3.27 is preached here. I would say according to most experience that a 3.73 is even steep for a supercharger. I would go to at least 3.55 if not a 3.27. Thge 3.27 gets my vote. Good luck.
ssj50driver is offline
post #3 of 7 Old 05-18-2009, 06:44 PM
jturmanator's Avatar
I am switching to the 3:27 gear. My 3:55 with almost identical combo puts me at around 5200-5500 rpm at the 1/4 in 4th. I think the 3:55 with the 2 step will alow me to run out 1st gear a little more which will help increase my 60' from a 1.85 to hopefully some 1.60's!
I think the 3:27 is definately better on the street for sure, the 3:55's make you have to shift to much. Oh im also running a 255/50/R16 M/T 26" tire
jturmanator is offline
post #4 of 7 Old 05-18-2009, 07:56 PM Thread Starter
hey all
what about 3.31.1 gears. the reason i ask is i got a free set with like 800 miles off my buddy's gt500. there is little difference between 331 and 327s
post #5 of 7 Old 05-18-2009, 08:39 PM
Rich G's Avatar
Trader Feedback: (35)
3.33:1 not going in an 8.8 lol
Rich G is offline
post #6 of 7 Old 05-19-2009, 09:27 AM
http://www.4wheelerssupply.com/catal...fcaf160e40fb24
You must have thought like a 3.30 or something that would fit in a 9".. .maybe not. Although the difference between a 3.27 and a 3.31 is not worth breaking a sweat over in the least. Very little difference at all. About nil if that is better for you. Good luck. Take the free one. Test it out by turning it if you are unsure.
post #7 of 7 Old 05-19-2009, 09:29 AM
Oh and if you doubt your friend's car has this ratio according to Ford at least for this year it says:
The 2009 Shelby GT500 Coupe and Convertible feature an exterior and interior appearance designed to maintain its
leadership in the Sports Car segment. Additionally, with the increased performance provided by the supercharged
and intercooled 5.4L V8 and the SVT-tuned suspension, the 2009 Shelby GT500 continues to deliver the high
performance you expect from SVT.
The following equipment is standard as indicated:
Shelby GT500
Powertrain/Functional
• Axle – modified 8.8" live axle w/3.31:1 gear ratio & limited slip differential
• Brakes – power 4-wheel disc with ABS & Traction Control (Brembo Front Rotors and Calipers)
• Engine – supercharged 5.4L 4V V8 w/intercooler
• Rear window defroster
• Remote keyless entry
• Speed control – steering wheel-mounted
• Suspension – SVT-tuned front & rear w/unique dampers & springs for Coupe & Convertible
• Transmission – Tremec 6-speed manual
Gear selection rxracer SVT & DOHC 0 05-09-2008 09:55 PM
Gear Selection Blownup5.0 General Mustang Tech 10 02-10-2006 10:41 PM
Gear Selection? 3.8ICEMAN Six Shooter 3 04-19-2005 10:45 AM
gear selection...3.73 or 3.90 19notchback90 GT & SOHC 15 02-29-2004 02:09 AM
Gear selection? ffr3247r General Mustang Tech 2 09-19-2002 10:50 AM
