vacuum lines - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 05-16-2009, 11:00 PM Thread Starter
pkstang's Avatar
Trader Feedback: (162)
Angry vacuum lines
just wanna make sure i'm not missing anything here...
#1) the blow off valve uses one of the manifiold ports
#2) the port on the compressor side of the turbo is just a test port and is not used
#3) the best way to run the MBC (manual boost controller) is to get a source before the tb (my tb has an npt port before the plate, which i plan to use), this line then goes to the bottom port on the MBC, the side port on the MBC then connects to the side port of the WG, and the top of the WG gets vented to atmosphere
am i right???
paul
pkstang is offline
post #2 of 4 Old 05-17-2009, 01:25 AM
Here is a picture i got from turbonetics web site. i am now running my valve for my ebc in place of the regulator(mbc), and my vacum line for the bov is coming off on my intake (behind the throttle body).
qk01lightning is offline
post #3 of 4 Old 05-17-2009, 11:04 AM
Your picture is not showing up. I think you have your mbc hooked up wrong. I tried it like that, and boost looked like it was going to keep climbing. The top of the wg should not be vented.
http://www.tialmedia.com/documents/w..._wginstall.pdf
1994 Turbo GT
mustangless is offline
post #4 of 4 Old 05-17-2009, 11:13 AM
That's weird i can see the picture fine, any way yes it show's the same routing of the vacum lines, i did actually have mine running that way at first also per a local import shop telling me (valve connected to bottom port and top vented) and i will tell you it climbed and climbed but i also had no adjustment with my boost controller until i rerouted it like your picture shows.
Anyone Have Vacuum Hose Diagram or Know Where Red Vacuum Lines Should Go To eazycj 94/95 Tech 4 04-26-2009 08:13 PM
vacuum lines 94Red5.0 94/95 Tech 2 05-31-2005 09:30 PM
Don't know where vacuum lines go?Boost lines? Bypass valve lines? marine4u123 Superchargers 4 05-17-2005 11:38 AM
vacuum lines NeptuneCrash 5.0/5.8 Engine Tech 0 04-27-2005 08:49 PM
vacuum lines--which ones do i really need? second2none 5.0/5.8 Engine Tech 0 07-03-2002 01:14 AM
