**** Have a BG turbo kit? COME INSIDE! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 12 Old 05-16-2009, 07:32 PM Thread Starter
Arrow **** Have a BG turbo kit? COME INSIDE!
I am having issues with my earls straight fitting hitting his flange and causing an oil leak because I cannot tighten it all the way. I do not want to have to grind on the flange. Anyone have any pictures they can take of your drain? Most importantly, just the way you have it set up on the turbo itself, not going into the pan.
Thanks in advance!
ChaseGT is offline
post #2 of 12 Old 05-16-2009, 07:59 PM
Rich G's Avatar
Trader Feedback: (35)
Not sure what you mean, I know mine was a pain to tighten but I was able to do it.
Rich G is offline
post #3 of 12 Old 05-16-2009, 08:02 PM Thread Starter
I just figured it out.. looks like I didn't clock the drain, like a dumbass.
Can I clock the center housing with the turbo bolted into the car? Here are a couple pictures of how it is setup (wrong).
ChaseGT is offline
post #4 of 12 Old 05-16-2009, 08:08 PM
Rich G's Avatar
I tried taking a pic but on the car its impossible.
When you say flange do you mean the plate that gets bolted onto the turbo?
Rich G is offline
post #5 of 12 Old 05-16-2009, 08:20 PM Thread Starter
ChaseGT is offline
post #6 of 12 Old 05-16-2009, 08:23 PM
Rich G's Avatar
yes you can clock it on the car but its a pain to loosen the bolts
Rich G is offline
post #7 of 12 Old 05-16-2009, 08:24 PM
Rich G's Avatar
Oh I see what your talking about, I drilled a hole in my frame for my drain to come out of .
Rich G is offline
post #8 of 12 Old 05-16-2009, 08:26 PM Thread Starter
Which set needs to be loosened? I'm not sure I want to drill a whole in the frame, I don't believe I will have the length of line to run that and I'm not going through the hastle of putting it together again. I think I can get away with a 15 degree angle or so and keep it outside the frame rail.
ChaseGT is offline
post #9 of 12 Old 05-16-2009, 08:28 PM
Rich G's Avatar
The 6 on the exhaust housing and the 6 on the cold side housing..
Be careful when rotating the cold side though, I did and tore the o-ring that was on the inside... and its FAR from a standard o-ring
Rich G is offline
post #10 of 12 Old 05-16-2009, 08:42 PM Thread Starter
####, I guess it'll be easier to just pull the turbo off the flange and re-RTV it. Bleh, tomorrow is gonnna be a fun day!
ChaseGT is offline
post #11 of 12 Old 05-16-2009, 08:44 PM
Rich G's Avatar
yea lol.. supposed to test fit all that stuff before rtv'ing it!
Rich G is offline
post #12 of 12 Old 05-16-2009, 08:45 PM Thread Starter
Got in the zone! Car has already been started and then I realized oil was leaking. DOH!
ChaseGT is offline
QuickTime Turbo Systems kit arrived today - pics and review inside ratedz Turbochargers 23 01-08-2008 02:19 AM
87-93 302 DYI TURBO KIT FOR TRADE looking for 94-95 Turbo kit stng5pnt8 Power Adders 3 07-17-2005 06:11 PM
Twin Turbo kit for 96-03 4.6 Mustang ( Pics inside) 01GT5speed GT & SOHC 7 01-30-2003 11:26 PM
