Timing question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-15-2009, 08:24 PM Thread Starter
Timing question
What are you turbo guys running for initial and total timing?
Are you pulling timing on the top? If so how much?
angcobra is offline
post #2 of 5 Old 05-15-2009, 09:23 PM
millhouse's Avatar
24* total up top @ 8lbs of boost on TFS aluminum heads with stock compression.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #3 of 5 Old 05-16-2009, 12:07 AM
I'm at 21* with ~8lbs on a stock long block running 91 octane.
millhouse, are you running 93 octane?
SonicFox is offline
post #4 of 5 Old 05-16-2009, 08:41 AM
millhouse's Avatar
Yep, usually 93. The local Sunoco has 94 as well, so I sometimes indulge.
post #5 of 5 Old 05-16-2009, 10:46 AM
10* initial and 18-19* on top. This is at 8lbs, 93 octane, and stock heads.
1994 Turbo GT
mustangless is offline
Timing question - confused about timing and horsepower jcm3 Superchargers 12 03-27-2007 02:46 PM
Timing question...Timing curve saleenboy87146 Superchargers 1 11-09-2005 06:32 AM
Question about pulling the timing chip when changing timing Chad Smith General Mustang Tech 7 05-28-2004 01:22 PM
Question about cam timing and timing chain Nitrous SSC 5.0/5.8 Engine Tech 1 04-09-2003 03:09 PM
timing question? were to read the timing broncoboy 5.0/5.8 Engine Tech 3 11-12-2002 08:12 PM
