70mm turbo car starts, then won't idle.. Any ideas? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 05-13-2009, 08:48 PM Thread Starter
So, car has fuel pressure and oil pressure. It has spark, and fires up great almost immediatly after cranking. It sounds healthy when it starts, a nice "VROOM" to it, then it just kind of dies and vac gauges shoots pretty low (14~vac?). I have a SCT chip that my tuner added the files for the 60# injectors on and he gave me a couple different tunes, one with -10 and +10 for fuel just to get it to his dyno. The car wants to run but for some reason it can't stay up to idle..
Any ideas?
As far as MAF, I have a C&L 76mm in a blow through config, with a good 8" of straight pipe on both sides.
ChaseGT is offline
post #2 of 10 Old 05-13-2009, 08:51 PM
Rich G's Avatar
Trader Feedback: (35)
Sure the idle isnt set to low on the chip?
Rich G is offline
post #3 of 10 Old 05-13-2009, 08:59 PM Thread Starter
Positive. We try to give the car gas and it tries to stay alive but can't. I have checked all my vac connections, all are good and zip tied, no leaks.
ChaseGT is offline
post #4 of 10 Old 05-13-2009, 11:59 PM
sleeeper88's Avatar
Whats the base timing at?
88 gt bigbore 347 ysi 23lbs boost. Best et. 9.09. Best mph 155. 3680lbs with 900rwhp @7000 thru aod tuned by Bob kurgan.
sleeeper88 is offline
post #5 of 10 Old 05-14-2009, 12:07 AM Thread Starter
Base timing is at 10, but if we try to advance or play with it it's still the same. I'm taking my chip to him tomorrow. I forgot the old tune had a Pro-M MAF and I'm now using stock, so that may be it. We'll see.
ChaseGT is offline
post #6 of 10 Old 05-14-2009, 06:17 AM
Rich G's Avatar
how are you setting base timing if it isnt idling?
Also that 10* is with spout out correct?
Rich G is offline
post #7 of 10 Old 05-14-2009, 11:49 AM
Do you have a way of monitoring narrow band o2 voltages?
Brian Turner
4 Mustangs and a Z06
Mobile Chassis Dyno is offline
post #8 of 10 Old 05-18-2009, 04:07 PM
Thunder5.0's Avatar
What is the fuel pressure set to? My C&L does not idle well either but when I am moving it is good.
You may have too much fuel. Check the plugs.
Thunder5.0 is offline
post #9 of 10 Old 05-19-2009, 04:18 PM
goat-ee's Avatar
Sure sounds like vacuum leak. Maybe a crack or a hose with a split?
96 Cobra Vert
NEW SETUP: 60'-1.830, 11.7 @ 121.73. Hellion Single Turbo @ 10psi. UD pullies, timing adjuster, Meziere WP, Bassani Quiet Thunder w/cats, 4.10's, AL driveshaft, 315/35/17 BFG DR's.
New Driver-97 Pacific Green Cobra. Forged, 2.1 Kenne Bell, T-56, 3.73. 12.6 @ 112mph
goat-ee is offline
post #10 of 10 Old 05-19-2009, 05:04 PM Thread Starter
Got it figured out, had to have the chip re-burnt, it didn't like the 60# files for some reason.
ChaseGT is offline
Help, car starts, wont idle andrewrj 94/95 Tech 2 10-18-2008 09:39 AM
Changed Plugs, Car ran for a while, then starts missing? Any ideas? ryanmac GT & SOHC 13 04-28-2004 01:46 AM
Car wont Idle...any ideas? chrisa351 GT & SOHC 4 01-02-2004 02:39 PM
Just put in re-ringed short block, car barely starts, really rough idle, please help SN95LEEN 5.0/5.8 Engine Tech 8 05-20-2003 04:32 AM
car misses at idle, and starts really hard bigfordfreak 5.0/5.8 Engine Tech 3 05-09-2002 12:53 AM
