Last Turbo Fuel Questions - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 05-11-2009, 09:58 PM Thread Starter
Trader Feedback: (25)
Hey Guys, Heres my last and final questions.
Heres my setup
302 (33,***)original miles
-Edelbrock Performer Aluminum Heads
-Ford E-Cam
-Edelbrock Performer Upper/Lower Intake
Cartech SS Turbo Kit
Percision 60mm turbo, and will be tuned at 10-14psi.
So far my fuel kit is
-stock sumped gas tank
-(-8 main feed line)
-(-6 return line)
-aeromotive y-block
-behind bars fuel rails
-aeromotive adj FPR
Planning on running
-60lb EV1 low imp. injectors
-Matching MAF
-SCT CHIP
Im trying to figure out how to route all the fuel line/filters/pumps/wiring ect.
Im thinking about running the GSL392 inline pump, should i run 1 or 2? How to run the filters. I know im in need of a 10 and 100 micron filters with -8 fittings.
Questions
1. Should I run 1 or 2 GSL392?
2. How to run the filters/pumps/wiring?
Please send some pictures of everything ran.
PS. This is a street/show car
Thanks Alot
PaT #06
94Stanggt5.0 is offline
post #2 of 9 Old 05-11-2009, 10:24 PM
I would run one pump, that is their high volume 255 inline right? What I did when I ran inline pumps is I got filters and fittings that allowed me to screw the filters into the pumps. As far as wiring I had a fusebox in the back of the car being fed by the battery then I used relays triggered by the factory wiring to engage my pumps.
post #3 of 9 Old 05-13-2009, 09:00 PM Thread Starter
yes i believe it is. Yea did u run the 100 and 10 micron fuel filters.
Do you happen to have any pictures of your set up?
post #4 of 9 Old 05-13-2009, 09:24 PM
I actually ran an inline Bosch pump and I just had post filters since that is all Kinsler told me I needed at the time. I do not know offhand what micron those were. I might have a picture somewhere of my dual inline Bosch pumps.
post #5 of 9 Old 05-19-2009, 09:51 PM Thread Starter
anyone have any more info/help
thanks alot
PaT #06
post #6 of 9 Old 06-03-2009, 04:29 PM Thread Starter
Hey Guys, Last question, just purchased my -8 and -6 fuel lines.
Im also recieving a BOSCH 390 inline pump. Im planning on just running this single pump to run my setup.
What do you think?
post #7 of 9 Old 06-03-2009, 04:32 PM
If that is the same one I used to run then it will be more than enough. I no longer recall what part number I had though.
post #8 of 9 Old 06-03-2009, 04:44 PM
You will be fine with 1.. no need for 2 when your still running the stock block.
ChaseGT is offline
post #9 of 9 Old 06-03-2009, 09:10 PM Thread Starter
alright sweet, thanks alot guys, I appreciate all the help you have given me.
GodBless
PaT#06
TURBO FUEL QUESTIONS 94Stanggt5.0 Turbochargers 19 04-09-2009 01:55 AM
Turbo cobra fuel system questions... 97QUICKSNAKE SVT & DOHC 8 05-28-2008 11:44 AM
Fuel System for Turbo Application - Questions ??? JC SVT & DOHC 12 08-13-2006 10:00 PM
Got a fuel questions for you turbo guys fastwhite86gt Turbochargers 9 11-22-2005 12:34 AM
Fuel System For A Turbo Questions stangitwell Turbochargers 4 06-01-2004 11:37 AM
