Considering Hellion "Heat" Fox Body Kit... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 05-10-2009, 06:45 PM Thread Starter
Coupester's Avatar
Trader Feedback: (41)
Guys, I'm seriously considering a Hellion "Heat" kit which retains a/c, etc. The craftsmanship looks incredible, etc. I'm interested in the small 62mm turbo... from what I've read this will be the perfect size for a stock motor 302 and will spool very quickly, while still allowing me to make ~450rwhp or maybe more. Is this accurate?
This will be on a stock 93 longblock (currently in the car). I am tempted to throw a set of P-heads (w/ TFS valvesprings), B-cam, Explorer intake, and a new timing chain that I have laying around on the motor, although I'd like to hear input on that...
A couple of issues I foresee having to deal with ... I have the MM forward offset a-arms which moves the swaybar forward. I have already heard of B&G guys having to trim their swaybar mount... is this also the case with the Hellion kit? Has anyone actually done the turbo kit with the swaybar mount pushed forward?
Thanks! Hope to be boostin' soon
82 Mercury Capri - N/A AFR 165, FTI cam 11.99 @ 112
86 LX Coupe - Coyote, T56, 11.55 @ 121
Coupester is offline
post #2 of 10 Old 05-12-2009, 11:52 PM
Thunder5.0's Avatar
I have the old Hellion kit here and have no regrets. Spools quickly and hold on.
Thunder5.0 is offline
post #3 of 10 Old 05-13-2009, 10:08 AM
CaliNotch n MI's Avatar
Trader Feedback: (15)
X2 I'm running TFS heads and Track heat intake with a stock cam shooting for 500 at the wheels, I'll be hitting the dyno in a few weeks.
1993 Notch: Mexican 347 Hellion TFS heads/GT40 intake/Custom Cam Tremec 3550
1992 GT Convert: Green/Blk interior, 10th anniversary cobra's mostly suspension mods.
FB users please, PLEASE click "like" button. Thanks!!
CaliNotch n MI is offline
post #4 of 10 Old 05-13-2009, 10:14 AM
Trader Feedback: (45)
If you can't hit 500, I'd consider selling the car
To the OP make sure to look around 90% of the kits out there have amazing craftsmanship. Don't pay for just a name.
1989 Ford Mustang Notch 5.0
1979 Ford Fairmont Boxtop (LSX/4.8/Big BW Turbo)
Speedy911 is offline
post #5 of 10 Old 05-13-2009, 10:55 AM
I might be wrong on this but I thought the Hellion kit did a rear crossover tube where as a lot of the other kits do a front crossover tube. I'd think that if that is the case that the chances of sway bar issues are greatly reduced but just call or email Hellion and they more than likely will know in regards to your concerns.
I personally would add everything you listed, since it is laying around with the exception of the B cam unless you just want a radical idle sound. Now I never have liked the B cam and have this negative opinion of it which does not help things. The stock cam works extremely well with turbo setups and at or above your stated power goal.
post #6 of 10 Old 05-13-2009, 11:15 AM
It looks like they may have changed things....
https://forums.corral.net/forums/show....php?t=1125057
post #7 of 10 Old 05-13-2009, 11:17 AM
Ah, well still would contact them, they tend to be a little bit helpful.
post #8 of 10 Old 05-13-2009, 03:23 PM
brian15's Avatar
yea looks like the new kit has the cross over in the front , i had the old style and everything about it was great .
62mm on a stock motor will be perfect for 450rwhp
brian15 is offline
post #9 of 10 Old 05-13-2009, 03:39 PM Thread Starter
Coupester's Avatar
The new kit is what I'm after ... talked to Hellion yesterday and we figured out that the rear crossover on the old kit would have to be completely redone for the T56 I have... and that it would hang down super low for a street car.
post #10 of 10 Old 05-13-2009, 04:21 PM
Thunder5.0's Avatar
The only problem with the old kit is that the rear crossover tube just barely clears my C-4 oil pan.
When I had the t-5 tranny in there, it was a good fit though.
Hellion 76mm kit for fox body Matt Grieve Power Adders 13 05-18-2007 07:28 AM
87-93 ""COMPLETE GT BODY KIT"" FOR SALE 03cobraguy Exterior Parts 9 06-16-2006 12:48 PM
"Help!"Anyone running 15x10" rims w/5.5"b.s. on a Fox body? Jay P. Wheels and Tires 6 03-01-2005 08:48 AM
