3" or 3 1/2" Downpipe? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-04-2009, 08:28 PM Thread Starter
how much power can a 3" dp support? what is the point where it makes more sense to change to a 3 1/2" dp? I have a ponydown kit with a 70mm precision turbo, looking to make 550-650 hp once I change the heads and get a better block. Car will be a street car with a 5 speed. I got the 3" dp with the ponydown kit, but don't know if I should just make a 3 1/2" pipe and y-pipe and be done with it or what? Can someone help me out?
got9lbs is offline
post #2 of 6 Old 05-04-2009, 11:19 PM
331merc's Avatar
i have heard from some good sources that you want a dp 1.25 times the diameter of the exhaust wheel diameter. So a 3.5" would be a good upgrade.
Mike 1986 Capri street car w/ a/c, p/s & p/w
Custom built T6 80mm s400sx based kit Shaunthony's built (Twin Trouble and Anthony Fury)
9.31 @ 146 1.39 60' on drag radials @ 3735# Kurgan tuned AEM EMS
80mm 718rwhp new 88mm 921rwhp No new track times yet
331merc is offline
post #3 of 6 Old 05-04-2009, 11:49 PM
If you go 3.5" I would section it and use vbands so you can change plusg easier.. the 3.5" is a bitch to get in/out of a fox.
ChaseGT is offline
post #4 of 6 Old 05-05-2009, 08:19 PM
orion_134's Avatar
Trader Feedback: (126)
Must have the sections if you have an ac accumulator. 3.5" is a tiiiiight fit with only 1/4" between trans and k-member.
Jesse
FOR SALE! 89 LX Coupe: 306, TFTW, F303, Vic Jr, 750dp, T70 at 14#, 4R70W 3k Edge, 3.73's, QA1, Pro3i, Baseline, Crane
AC, PS, Street Car!
7# times: 1.56 [email protected] [email protected]
SSGT USMC Infantry 3x Veteran
orion_134 is offline
post #5 of 6 Old 05-06-2009, 12:00 PM
97SVT's Avatar
i ran a 3" for years w/ a MPT70, i can imagine trying to snake a 3.5" in and out would be tricky
1967 Mustang Coupe
1990 Mustang GT Turbod DD
1987 Mustang GT Turbod-9.75 @ 140mph gone but not forgotten
97SVT is offline
post #6 of 6 Old 05-06-2009, 12:08 PM
NC STANG GUY's Avatar
Trader Feedback: (176)
My 89 vert's BG kit has a 3.5dp.
It is very tight by the firewall/ac accumulator but it fits. No big deal to take off now that I know what sequence to do it in.
It is not sectioned either. Connects to my Y pipe before the trans crossmember. Worst part is that you have to line up the wastegate flange at the same time as the v band on the outlet on the turbo on my kit.
NC STANG GUY is offline
FS/FT PTK 5" downpipe bradinwva Power Adders 1 05-18-2007 08:19 PM
WTB 3" Downpipe peporacing Power Adders 1 06-21-2006 12:42 AM
WTB: 3/3.5" Downpipe peporacing Exhaust Parts 2 09-07-2005 12:53 PM
3.5" downpipe... HP limits superdavemfb Turbochargers 15 12-09-2004 03:57 PM
Is there ANY 3.5" catback available at all? Id like it to match my 3.5" downpipe. A.Brown GT & SOHC 5 04-03-2003 07:33 AM
